Component: LED MultiColour Bi (5mm, PCB) (LED)
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category LED
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_bicolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_bicolour.fcfx
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LED Resistor Calculator Tool
LEDOff
Switches off the LED
LEDSetState
Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2
- BYTE State
0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High
LEDOneOn
Switches on LED one
LEDTwoOn
Switches on LED two
Pin
LED Pin 1
Pin2
LED Pin 2
Color
The color of the LED when pin1 is turned on and pin2 is turned off.
Color2
The color of the LED when pin1 is turned off and pin2 is turned on.
Trim Leads
Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
LEDOff
LEDSetState
- BYTE State
LEDOneOn
Switches on LED one
LEDTwoOn
Switches on LED two
Pin
LED Pin 1
Pin2
LED Pin 2
Color
Color2
Trim Leads
Color
Scale
Follow Zoom
LEDOff
LEDSetState
- BYTE State
LEDOneOn
Switches on LED one
LEDTwoOn
Switches on LED two
Pin
LED Pin 1
Pin2
LED Pin 2
Color
Color2
Trim Leads
Color
Scale
Follow Zoom
