Component: Accelerometer 3-Axis (LIS3DHTR) (LIS3DHTR) (Movement Orientation)
Revision as of 09:52, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Movement Orientation
Accelerometer 3-Axis (LIS3DHTR) component
LIS3DHTR 3-Axis Accelerometer sensor.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_LIS3DHTR.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_LIS3DHTR.fcfx
Read_Register
Reads a value from a register on the accelerometer.
- BYTE Reg
SimReset1G
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
- BYTE Data
SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
Bit Depth
Accel Data Rate
Accel Scale
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
Read_Register
- BYTE Reg
SimReset1G
Write_Register
- BYTE Reg
- BYTE Data
SimSetAccelerometer
- INT X
- INT Y
- INT Z
CollectXYZData
- BYTE Axis
- INT Return
Bit Depth
Accel Data Rate
Accel Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
Read_Register
- BYTE Reg
SimReset1G
Write_Register
- BYTE Reg
- BYTE Data
SimSetAccelerometer
- INT X
- INT Y
- INT Z
CollectXYZData
- BYTE Axis
- INT Return
Bit Depth
Accel Data Rate
Accel Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
Read_Register
- BYTE Reg
SimReset1G
Write_Register
- BYTE Reg
- BYTE Data
SimSetAccelerometer
- INT X
- INT Y
- INT Z
CollectXYZData
- BYTE Axis
- INT Return
Bit Depth
Accel Data Rate
Accel Scale
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
