Component: CAN (Internal, MCP2515) (Comms: Interface)
Revision as of 09:52, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.10
Category Comms: Interface
CAN (Internal, MCP2515) component
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection or using an internal CAN peripheral if available on your device. Both methods will require a CAN driver IC like the MCP2551 to drive the CAN signals on the bus.
Please click here to download the component source project: FC_Comp_Source_CAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CAN.fcfx
ReadSwitches
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
SetTxData
Assigns one of the outgoing transmit buffers with data ready to be sent.
- BYTE Buffer
- BYTE Count
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
SetRxMask
Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
- BYTE Mask
Specifies which receive mask to modify. Range: 0-1
- ULONG ID
The ID mask value you wish to use
GetRxData
Returns last received message data byte at position Index. Buffer parameter is currently ignored
- BYTE Buffer
- BYTE Index
GetRxIDHi
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
Receive Buffer. Range 0-1
SetTxIDSimple
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
- BYTE Buffer
Transmit buffer to load. Range: 0-2
- UINT ID
The ID value you wish to use. Range: 0-2047
SendBuffer
Transmits one of the transmit buffers which should have already been populated with an ID and data.
- BYTE Buffer
Specifies which transmit buffer to send
GetRxDataCount
Returns last received message data length. Buffer parameter is currently ignored
- BYTE Buffer
SetRxFilterID
sets the Filter Standard mode only (for V5 compatibility only)
- BYTE Filter
Specifies which filter to modify. Range: 0-5
- BYTE Hi
ID bits 3-10
- BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte
GetRxIDLo
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
SetRxMaskID
set the Mask Standard ID mode only (for V5 compatibility)
- BYTE Mask
- BYTE Hi
ID bits 3-10
- BYTE Lo
SetRxFilter
Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
- BYTE Filter
Specifies which receive filter to modify. Range: 0-5
- ULONG ID
The ID filter value you wish to use
SetTxIdent
Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
- BYTE Buffer
- ULONG ID
The ID or Extended ID value you wish to use. Range: 0-536870911
CheckRx
Checks to see if any messages are available for 'Buffer' specified
- BYTE Buffer
Send buffer: 0 to 1
ChangeRate
Simple attempt to alter the bus rate of the CAN. External CAN channels only,
- BYTE Rate
Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000
GetRxIDSimple
Gets the Rx ID as a Integer Standard ID only 0-2047.
- BYTE Buffer
SetTxID
Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE Buffer
- BYTE Hi
ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
- BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
ShowLEDs
Set LED state (External CAN only)
- BYTE led1
Controls LED 1. Range: 0-1
- BYTE led2
Controls LED 2. Range: 0-1
GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
- BYTE Buffer
- ULONG Return
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
Sync Jump Width
Defines how far a resyncronisation may move the sample point
Sample Point
Point in each bit period where the incoming data is sampled.
ID Type
Switches between using Standard, or Standard and Extended CAN
One Shot Mode
Disabled. Messages will reattempt transmission Enabled. Message will only attempt to transmit once
SPI
CHANNEL
SPI Channel selector
MOSI
MISO
CLK
SS
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
TX Buffer 0
Message ID
TX Buffer 0 Message Identifier
Length
TX Buffer 0 Number of data bytes
D0
TX Buffer 0 Data Byte 0
D1
TX Buffer 0 Data Byte 1
D2
TX Buffer 0 Data Byte 2
D3
TX Buffer 0 Data Byte 3
D4
TX Buffer 0 Data Byte 4
D5
TX Buffer 0 Data Byte 5
D6
TX Buffer 0 Data Byte 6
D7
TX Buffer 0 Data Byte 7
TX Buffer 1
Message ID
TX Buffer 1 Message Identifier
Length
TX Buffer 1 Number of data bytes
D0
TX Buffer 1 Data Byte 0
D1
TX Buffer 1 Data Byte 1
D2
TX Buffer 1 Data Byte 2
D3
TX Buffer 1 Data Byte 3
D4
TX Buffer 1 Data Byte 4
D5
TX Buffer 1 Data Byte 5
D6
TX Buffer 1 Data Byte 6
D7
TX Buffer 1 Data Byte 7
TX Buffer 2
Message ID
TX Buffer 2 Message Identifier
Length
TX Buffer 2 Number of data bytes
D0
TX Buffer 2 Data Byte 0
D1
TX Buffer 2 Data Byte 1
D2
TX Buffer 2 Data Byte 2
D3
TX Buffer 2 Data Byte 3
D4
TX Buffer 2 Data Byte 4
D5
TX Buffer 2 Data Byte 5
D6
TX Buffer 2 Data Byte 6
D7
TX Buffer 2 Data Byte 7
RX Buffer 0
Settings
RX Buffer 0 Message Receive Mode
RX Buffer 1
Settings
RX Buffer 1 Message Receive Mode
Comms Flasher Identification Label
Simulate SPI Comms
ReadSwitches
SetTxData
- BYTE Buffer
- BYTE Count
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
SetRxMask
- BYTE Mask
- ULONG ID
GetRxData
- BYTE Buffer
- BYTE Index
GetRxIDHi
- BYTE Buffer
SetTxIDSimple
- BYTE Buffer
- UINT ID
SendBuffer
- BYTE Buffer
GetRxDataCount
- BYTE Buffer
SetRxFilterID
- BYTE Filter
- BYTE Hi
ID bits 3-10
- BYTE Lo
GetRxIDLo
- BYTE Buffer
SetRxMaskID
- BYTE Mask
- BYTE Hi
ID bits 3-10
- BYTE Lo
SetRxFilter
- BYTE Filter
- ULONG ID
SetTxIdent
- BYTE Buffer
- ULONG ID
CheckRx
- BYTE Buffer
Send buffer: 0 to 1
ChangeRate
- BYTE Rate
GetRxIDSimple
- BYTE Buffer
SetTxID
- BYTE Buffer
- BYTE Hi
- BYTE Lo
ShowLEDs
- BYTE led1
- BYTE led2
GetRxIdent
- BYTE Buffer
- ULONG Return
Controller Osc
Bus Rate
Sync Jump Width
Sample Point
ID Type
One Shot Mode
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
ReadSwitches
SetTxData
- BYTE Buffer
- BYTE Count
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
SetRxMask
- BYTE Mask
- ULONG ID
GetRxData
- BYTE Buffer
- BYTE Index
GetRxIDHi
- BYTE Buffer
SetTxIDSimple
- BYTE Buffer
- UINT ID
SendBuffer
- BYTE Buffer
GetRxDataCount
- BYTE Buffer
SetRxFilterID
- BYTE Filter
- BYTE Hi
ID bits 3-10
- BYTE Lo
GetRxIDLo
- BYTE Buffer
SetRxMaskID
- BYTE Mask
- BYTE Hi
ID bits 3-10
- BYTE Lo
SetRxFilter
- BYTE Filter
- ULONG ID
SetTxIdent
- BYTE Buffer
- ULONG ID
CheckRx
- BYTE Buffer
Send buffer: 0 to 1
ChangeRate
- BYTE Rate
GetRxIDSimple
- BYTE Buffer
SetTxID
- BYTE Buffer
- BYTE Hi
- BYTE Lo
ShowLEDs
- BYTE led1
- BYTE led2
GetRxIdent
- BYTE Buffer
- ULONG Return
Controller Osc
Bus Rate
Sync Jump Width
Sample Point
ID Type
One Shot Mode
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
ReadSwitches
SetTxData
- BYTE Buffer
- BYTE Count
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
SetRxMask
- BYTE Mask
- ULONG ID
GetRxData
- BYTE Buffer
- BYTE Index
GetRxIDHi
- BYTE Buffer
SetTxIDSimple
- BYTE Buffer
- UINT ID
SendBuffer
- BYTE Buffer
GetRxDataCount
- BYTE Buffer
SetRxFilterID
- BYTE Filter
- BYTE Hi
ID bits 3-10
- BYTE Lo
GetRxIDLo
- BYTE Buffer
SetRxMaskID
- BYTE Mask
- BYTE Hi
ID bits 3-10
- BYTE Lo
SetRxFilter
- BYTE Filter
- ULONG ID
SetTxIdent
- BYTE Buffer
- ULONG ID
CheckRx
- BYTE Buffer
Send buffer: 0 to 1
ChangeRate
- BYTE Rate
GetRxIDSimple
- BYTE Buffer
SetTxID
- BYTE Buffer
- BYTE Hi
- BYTE Lo
ShowLEDs
- BYTE led1
- BYTE led2
GetRxIdent
- BYTE Buffer
- ULONG Return
Controller Osc
Bus Rate
Sync Jump Width
Sample Point
ID Type
One Shot Mode
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
