Author
Matrix Ltd.
Version
2.0
Category
Movement Orientation
Accelerometer 3-Axis (MMA8452Q) component
MMA8452Q Accelerometer sensor with I2C. Useful for approximating Pitch and Roll or for detecting acceleration.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Read_Register
Reads a value from a register on the accelerometer.
- BYTE
Reg
Register address to read from
- BYTE
SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE
Reg
Register Address to Write to
- BYTE
Data
Value to write to the register
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
- INT
UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
Read_N_Registers
Reads a set of data values from sequential registers on the accelerometer
- BYTE
Start_Reg
First address to read data from
- BYTE
Num_Regs
Number of registers to read
- BYTE
data
Data variable to populate with the register values
SimSetXYZ
Allows the XYZ slider values to be set via the simulation
- INT
X
- INT
Y
- INT
Z
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
Bit Depth
The number of binary bits used to store the sensor's X,Y,Z readings.
Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Data Rate
Int Option
Sets if we use the interrupt pin to check if new data is available
Device Address
I2C Connections
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Read_Register
- BYTE
Reg
- BYTE
SimReset1G
Write_Register
- BYTE
Reg
- BYTE
Data
CollectXYZData
- BYTE
Axis
- INT
UpdateXYZData
- BYTE
Read_N_Registers
- BYTE
Start_Reg
- BYTE
Num_Regs
- BYTE
data
SimSetXYZ
- INT
X
- INT
Y
- INT
Z
- BYTE
Bit Depth
Scale
Data Rate
Int Option
Device Address
I2C Connections
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
