Author
Version
1.0
Category
Outputs
Analogue LED component
An LED with variable brightness. Simulation Only. Brightness can be set either by macro call or by connection to an analogue pin.
Please click here to download the component source project: FC_Comp_Source_Analogue_LED.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Analogue_LED.fcfx
Example Program showing how to show the temperature in Celsius and Fahrenheit and expected ADC pin voltage on an LCD.
Analogue Sensors Example
SetBrightness
Set the brightness of the LED.
- FLOAT
Brightness
Brightness from 0.0 to 1.0
[[File:]] -
Analogue
Choose an analogue pin to connect to the LED. When the analogue value changes, the LED brightness will be updated.
Color Range
On Color
LED color when at maximum brightness
Off Color
LED color when at minimum brightness
Auto Off
When AutoOff is enabled, the Off Color is automatically set whenever the On Color is changed. The automatic off color will be the same hue as the on color, but 25% of the brightness.
Minimum
Input value that gives the darkest LED color.
Maximum
Input value that gives the brightest LED color.
Shape
Target
A panel object to be treated as the illuminating part of the LED. If unconnected, a built-in default shape can be chosen.
Shape
Choose a shape for the LED.
Width
Width of the LED shape.
Height
Height of the LED shape.
Depth
Depth of the LED shape.
SetBrightness
- FLOAT
Brightness
[[File:]] -
Analogue
Color Range
On Color
Off Color
Auto Off
Minimum
Maximum
Shape
Target
Shape
Width
Height
Depth
SetBrightness
- FLOAT
Brightness
[[File:]] -
Analogue
Color Range
On Color
Off Color
Auto Off
Minimum
Maximum
Shape
Target
Shape
Width
Height
Depth
SetBrightness
- FLOAT
Brightness
[[File:]] -
Analogue
Color Range
On Color
Off Color
Auto Off
Minimum
Maximum
Shape
Target
Shape
Width
Height
Depth
SetBrightness
- FLOAT
Brightness
[[File:]] -
Analogue
Color Range
On Color
Off Color
Auto Off
Minimum
Maximum
Shape
Target
Shape
Width
Height
Depth
