Component: Buzzer (Audio Output)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Category Audio Output
Buzzer component
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation. To actually drive a buzzer you would have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here to download the component source project: FC_Comp_Source_Buzzer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Buzzer.fcfx
Depending on your Buzzer you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
A basic buzzer example using all the buzzer functions.
It should be noted that if you have a single BuzzerOn component with no loop, the buzzer sound will stop when the simulation stops.
The pin will remain high.
While the buzzer is on, the simulation tone is not continuous, it rapidly pulses, the pin will remain high.
That is not a bug with the component
FC6 Icon.png Basic Buzzer Example
Fc9-comp-macro.png BuzzerBeep
Switches the buzzer on and off automatically to allow for a series of beeps
Fc9-u16-icon.png - UINT OnTime
Length of time in ms the buzzer will remain on
Fc9-u16-icon.png - UINT OffTime
Length of time in ms the buzzer will remain off
Fc9-u8-icon.png - BYTE NumberLoops
Number of times to repeat the sequence. Range 1-255
Fc9-comp-macro.png BuzzerOff
Switch Off the Buzzer
Fc9-comp-macro.png BuzzerOn
Switch On the Buzzer
Fc9-comp-macro.png BuzzerOnDelay
Switch the Buzzer on for a fixed amount of time
Fc9-u16-icon.png - UINT Time
Time in milliseconds to keep the buzzer on
Fc9-type-5-icon.png Output Pin
Pin used to drive the output to the buzzer
Fc9-type-16-icon.png Polarity
Controls the pin state required to switch the buzzer on.
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Buzzer Frequency
Frequency of the buzzer in Hz to drive the simulation
