Component: Offset (DSP Operators)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category DSP Operators
Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Please click here to download the component source project: FC_Comp_Source_DSP_Offset.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Offset.fcfx
Calculate
Performs the selected offset on a value from the input buffer and passes to the output buffer.
CalculateArray
Performs the selected offset on an entire buffer.
SetOffset
Sets the Offset to be used when calling the calculate function.
- INT Offset
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Offset
Offset Type
Defines the type of calculation performed on the input buffer to obtain the output value. A left shift is essentially an optimised multiply with the multiplier being the 2^scaler A right shift is essentially an optimised divide with the divider being the 2^scaler
Rollover
Allow the output buffer to rollover. For example 128 + 128 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled. With rollover disabled the output would be set to 255 which is the max representable value.
Initial Offset
Calculate
CalculateArray
SetOffset
- INT Offset
Connect To
Buffer Size
Buffer Type
Direction
Offset
Offset Type
Rollover
Initial Offset
Calculate
CalculateArray
SetOffset
- INT Offset
Connect To
Buffer Size
Buffer Type
Direction
Offset
Offset Type
Rollover
Initial Offset
Calculate
CalculateArray
SetOffset
- INT Offset
Connect To
Buffer Size
Buffer Type
Direction
Offset
Offset Type
Rollover
Initial Offset
