Component: Servo Motor (BL0162) (E-blocks 2)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Servo Motor component
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board. Provides up to eight individually addressable connections for standard DC servo motors to be connected.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Servo_BL0162.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Servo_BL0162.fcfx
DisableServo
Disables a servo channel effectivly disabling the motor.
- BYTE Channel
The channel to set the position for. First channel is zero.
SetPosition
Moves directly to the specified position with no interpolation.
- BYTE Channel
- BYTE Position
Target position to move towards.
IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
- BYTE Position
SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE Channel
- BYTE Trim
0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us
AutoMoveToPosition
Automatically moves towards the new position with a fixed rate of 100 steps per second.
- BYTE Channel
- BYTE Position
Position to move to.
EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE Channel
SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is 1.
- BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Sets up the servo motor interrupts
Channels (1 - 8)
Set the number of servo's that you need to control. Value from 1 to 8.
Channel 0
Pin on which to output PWM for the servo motor.
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Pulse Width
Minimum (us)
Shortest pulse width that will be used.
Maximum (us)
Longest pulse width used for the PWM signals.
Trim
Trim 0
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Trim 1
Trim 2
Trim 3
Trim 4
Trim 5
Trim 6
Trim 7
Show Servo Interface
Servo Object 0
Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
Servo Object 1
Servo Object 2
Servo Object 3
Servo Object 4
Servo Object 5
Servo Object 6
Servo Object 7
DisableServo
- BYTE Channel
SetPosition
- BYTE Channel
- BYTE Position
IsAutoMoving
MoveToPosition
- BYTE Channel
- BYTE Position
SetTrim
- BYTE Channel
- BYTE Trim
AutoMoveToPosition
- BYTE Channel
- BYTE Position
EnableServo
- BYTE Channel
SetAutoMoveSpeed
- BYTE Speed
Channels (1 - 8)
Channel 0
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Pulse Width
Minimum (us)
Maximum (us)
Trim
Trim 0
Trim 1
Trim 2
Trim 3
Trim 4
Trim 5
Trim 6
Trim 7
Servo Object 0
Servo Object 1
Servo Object 2
Servo Object 3
Servo Object 4
Servo Object 5
Servo Object 6
Servo Object 7
DisableServo
- BYTE Channel
SetPosition
- BYTE Channel
- BYTE Position
IsAutoMoving
MoveToPosition
- BYTE Channel
- BYTE Position
SetTrim
- BYTE Channel
- BYTE Trim
AutoMoveToPosition
- BYTE Channel
- BYTE Position
EnableServo
- BYTE Channel
SetAutoMoveSpeed
- BYTE Speed
Channels (1 - 8)
Channel 0
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Pulse Width
Minimum (us)
Maximum (us)
Trim
Trim 0
Trim 1
Trim 2
Trim 3
Trim 4
Trim 5
Trim 6
Trim 7
Servo Object 0
Servo Object 1
Servo Object 2
Servo Object 3
Servo Object 4
Servo Object 5
Servo Object 6
Servo Object 7
DisableServo
- BYTE Channel
SetPosition
- BYTE Channel
- BYTE Position
IsAutoMoving
MoveToPosition
- BYTE Channel
- BYTE Position
SetTrim
- BYTE Channel
- BYTE Trim
AutoMoveToPosition
- BYTE Channel
- BYTE Position
EnableServo
- BYTE Channel
SetAutoMoveSpeed
- BYTE Speed
Channels (1 - 8)
Channel 0
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Pulse Width
Minimum (us)
Maximum (us)
Trim
Trim 0
Trim 1
Trim 2
Trim 3
Trim 4
Trim 5
Trim 6
Trim 7
Servo Object 0
Servo Object 1
Servo Object 2
Servo Object 3
Servo Object 4
Servo Object 5
Servo Object 6
Servo Object 7
