| Author
MatrixTSL
| Version
1.0
| Category
EEPROM
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_EEPROM_DS28E07.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM_DS28E07.fcfx
SetString
| Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
- UINT
Address
| Address of the value to write
- STRING
Value
| Data string to write
GetString
| Gets a string from the specified start address.
- UINT
Address
| Address of the first data byte
- BYTE
MaxLength
| Maximum number of bytes in the string, also includes null termination byte
- STRING
SetByteArray
| Writes an array of bytes to the EE memory.
- UINT
Address
| Starting address of the first value to write
- BYTE
Data
- BYTE
Count
| Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
| Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
- UINT
Address
- UINT
Value
| 16-bit value to write
- BOOL
MSBFirst
| 0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
| Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING
SerialNumber
| 48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
| Gets the Serial String for the current addressed device.
- STRING
AddressNextDevice
| Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
SetLong
| Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
- UINT
Address
- ULONG
Value
| 32-bit value to write
- BOOL
MSBFirst
GetFloat
| Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
- INT
Address
| The starting byte address
- BOOL
MSBFirst
- FLOAT
GetLong
| Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
| Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
| Reads an array of bytes starting from the selected address.
- UINT
Address
| Starting address of the first value to read
- BYTE
Data
| Byte array to store incoming data
- UINT
Count
| Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
| Writes a single byte to the EE memory.
- UINT
Address
- BYTE
Data
GetByte
| Reads a single byte from the selected address.
- UINT
Address
| Address of the value to read
- BYTE
SetFloat
| Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
- UINT
Address
- FLOAT
Value
| Floating point value to write
- BOOL
MSBFirst
| Configures each matching sensor on the bus with the specified conversion bits.
One Wire Component
| Link to the one wire component to host the bus.
EEPROM Size (Bytes)
Simulate Comms
| No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Panel Simulation
Number EE Devices
| Sens the number of sensors we can communicate with during simulation
Serial 0
| Serial number for simulated one wire device
SetString
- UINT
Address
- STRING
Value
GetString
- UINT
Address
- BYTE
MaxLength
- STRING
SetByteArray
- UINT
Address
- BYTE
Data
- BYTE
Count
SetInt
- UINT
Address
- UINT
Value
- BOOL
MSBFirst
- STRING
SerialNumber
GetSerialString
- STRING
AddressNextDevice
SetLong
- UINT
Address
- ULONG
Value
- BOOL
MSBFirst
GetFloat
- INT
Address
- BOOL
MSBFirst
- FLOAT
GetLong
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
- UINT
Address
- BYTE
Data
- UINT
Count
SetByte
- UINT
Address
- BYTE
Data
GetByte
- UINT
Address
- BYTE
SetFloat
- UINT
Address
- FLOAT
Value
- BOOL
MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
SetString
- UINT
Address
- STRING
Value
GetString
- UINT
Address
- BYTE
MaxLength
- STRING
SetByteArray
- UINT
Address
- BYTE
Data
- BYTE
Count
SetInt
- UINT
Address
- UINT
Value
- BOOL
MSBFirst
- STRING
SerialNumber
GetSerialString
- STRING
AddressNextDevice
SetLong
- UINT
Address
- ULONG
Value
- BOOL
MSBFirst
GetFloat
- INT
Address
- BOOL
MSBFirst
- FLOAT
GetLong
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
- UINT
Address
- BYTE
Data
- UINT
Count
SetByte
- UINT
Address
- BYTE
Data
GetByte
- UINT
Address
- BYTE
SetFloat
- UINT
Address
- FLOAT
Value
- BOOL
MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
SetString
- UINT
Address
- STRING
Value
GetString
- UINT
Address
- BYTE
MaxLength
- STRING
SetByteArray
- UINT
Address
- BYTE
Data
- BYTE
Count
SetInt
- UINT
Address
- UINT
Value
- BOOL
MSBFirst
- STRING
SerialNumber
GetSerialString
- STRING
AddressNextDevice
SetLong
- UINT
Address
- ULONG
Value
- BOOL
MSBFirst
GetFloat
- INT
Address
- BOOL
MSBFirst
- FLOAT
GetLong
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
- UINT
Address
- BYTE
Data
- UINT
Count
SetByte
- UINT
Address
- BYTE
Data
GetByte
- UINT
Address
- BYTE
SetFloat
- UINT
Address
- FLOAT
Value
- BOOL
MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
