Component: Keyboard (Digital Control )
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Category Digital Control
Keyboard component
Component to allow you to get direct input from the keyboard. Specific keys can be polled to test if they are pressed and provide interaction with the runtime panel. A full list of virtual key codes can be found here: https://docs.microsoft.com/en-gb/windows/win32/inputdev/virtual-key-codes?redirectedfrom=MSDN
Please click here to download the component source project: FC_Comp_Source_Keyboard.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Keyboard.fcfx
Here is an example of how to use the keyboard component to map key pressed to various functions on the panel.
Keyboard Example
You can define keys that can be changed by the user by right clicking the keys in the keyboard component property and exposing them to the top level.
Once the properties have been exposed you can double click the top level property and rename to give a meaningful name in your application.
The user can then easily select which key they would like to assign to each function.
GetKeyPress
Checks a single virtual key code to test if the button is pressed or not.
- BYTE KeyCode
Virtual Key Code Number
CheckMultipleKeys
Checks all of the keys enabled in the component properties. If any keys are pressed then their scan index number is returned. If no keys are pressed then 0 is returned.
Number of Scan Keys
Sets the number of keys to scan through when calling the CheckMultipleKeys function.
Scan Key 1
Virtual Keycode assigned to the scan index
Scan Key 2
Scan Key 3
Scan Key 4
GetKeyPress
- BYTE KeyCode
CheckMultipleKeys
Number of Scan Keys
Scan Key 1
Scan Key 2
Scan Key 3
Scan Key 4
GetKeyPress
- BYTE KeyCode
CheckMultipleKeys
Number of Scan Keys
Scan Key 1
Scan Key 2
Scan Key 3
Scan Key 4
GetKeyPress
- BYTE KeyCode
CheckMultipleKeys
Number of Scan Keys
Scan Key 1
Scan Key 2
Scan Key 3
Scan Key 4
