Component: MIAC NXT AllCode API (AllCode)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category AllCode
MIAC NXT AllCode API component
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_AllCode_Component_Source.fcsx
WriteTranPWMEnable
Allows pulse width modulated transistor outputs to be switched on or off.
- BYTE Channel
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
- BOOL EnableOrState
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
- BOOL OnOrOff
1 = Enabled / 0 = Disabled
WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
- BYTE Value
Range: 0-63 or 0b000000 to 0b111111
DisplayPrint
Prints a string to the MIAC display starting from the current cursor position.
- STRING data
Range: 0-21
GetAPIVersion
Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands.
DisplayNumber
Prints a number to the MIAC display starting from the current cursor position.
- LONG Value
Range: Signed Long
WriteTranPWMDuty
Sets the PWM duty on the selected channel.
- BYTE Channel
- UINT Duty
DisplayClear
Clears the MIAC display
ReadKey
Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc
DisplayPixel
Controls a single pixel on the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-31
- BOOL State
Range: 0-1
WriteRelay
Allows a single relay to be switched on or off.
- BYTE Channel
Range 1-2
- BOOL Value
0 = Off, 1 = On
WriteRelays
Allows all relays to be switched on or off in a single command.
- BYTE Value
Range: 0-3 or 0b00 to 0b11
ReadAnalogInput
Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V.
- BYTE Channel
Range: 1 - 8
SetAPIVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BOOL Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
DisplayCursor
Sets the cursor position for the MIAC display
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-3
ReadDigitalInput
Reads a single digital input.
- BYTE Channel
Range: 1 - 8
ReadDigitalInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
WriteTran
Allows a single transistor output to be switched on or off.
- BYTE Channel
Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- BOOL Value
0 = Off, 1 = On
DisplayFloat
Prints a floating point number to the MIAC display starting from the current cursor position.
- FLOAT Value
Range: Float
- BYTE NumDP
Number of decimal places to display
API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
Warnings On Error
Generates a warning dialogue if the communication to the device fails allowing the program to be ended.
Connection Properties
Auto Detect
WriteTranPWMEnable
- BYTE Channel
- BOOL OnOrOff
WriteTrans
- BYTE Value
DisplayPrint
- STRING data
Range: 0-21
GetAPIVersion
DisplayNumber
- LONG Value
Range: Signed Long
WriteTranPWMDuty
- BYTE Channel
- UINT Duty
DisplayClear
ReadKey
DisplayPixel
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-31
- BOOL State
Range: 0-1
WriteRelay
- BYTE Channel
Range 1-2
- BOOL Value
0 = Off, 1 = On
WriteRelays
- BYTE Value
ReadAnalogInput
- BYTE Channel
Range: 1 - 8
SetAPIVerbose
- BOOL Mode
DisplayCursor
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-3
ReadDigitalInput
- BYTE Channel
Range: 1 - 8
ReadDigitalInputs
WriteTran
- BYTE Channel
- BOOL Value
0 = Off, 1 = On
DisplayFloat
- FLOAT Value
Range: Float
- BYTE NumDP
API Connection Type
Warnings On Error
Auto Detect
WriteTranPWMEnable
- BYTE Channel
- BOOL OnOrOff
WriteTrans
- BYTE Value
DisplayPrint
- STRING data
Range: 0-21
GetAPIVersion
DisplayNumber
- LONG Value
Range: Signed Long
WriteTranPWMDuty
- BYTE Channel
- UINT Duty
DisplayClear
ReadKey
DisplayPixel
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-31
- BOOL State
Range: 0-1
WriteRelay
- BYTE Channel
Range 1-2
- BOOL Value
0 = Off, 1 = On
WriteRelays
- BYTE Value
ReadAnalogInput
- BYTE Channel
Range: 1 - 8
SetAPIVerbose
- BOOL Mode
DisplayCursor
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-3
ReadDigitalInput
- BYTE Channel
Range: 1 - 8
ReadDigitalInputs
WriteTran
- BYTE Channel
- BOOL Value
0 = Off, 1 = On
DisplayFloat
- FLOAT Value
Range: Float
- BYTE NumDP
API Connection Type
Warnings On Error
Auto Detect
WriteTranPWMEnable
- BYTE Channel
- BOOL OnOrOff
WriteTrans
- BYTE Value
DisplayPrint
- STRING data
Range: 0-21
GetAPIVersion
DisplayNumber
- LONG Value
Range: Signed Long
WriteTranPWMDuty
- BYTE Channel
- UINT Duty
DisplayClear
ReadKey
DisplayPixel
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-31
- BOOL State
Range: 0-1
WriteRelay
- BYTE Channel
Range 1-2
- BOOL Value
0 = Off, 1 = On
WriteRelays
- BYTE Value
ReadAnalogInput
- BYTE Channel
Range: 1 - 8
SetAPIVerbose
- BOOL Mode
DisplayCursor
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-3
ReadDigitalInput
- BYTE Channel
Range: 1 - 8
ReadDigitalInputs
WriteTran
- BYTE Channel
- BOOL Value
0 = Off, 1 = On
DisplayFloat
- FLOAT Value
Range: Float
- BYTE NumDP
API Connection Type
Warnings On Error
Auto Detect
