Author
Matrix TSL
Version
1.0
Category
Analog Input
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
Potentiometer Example
ReadAsInt
Read the ADC at full bit depth
- INT
GetValue
Get the Float value, between lower and upper bounds. Used on App Developer
- FLOAT
ReadAsFloat
Reads the ADC as a direct voltage
- FLOAT
SetValue
Sets the Float value, between lower and upper bounds. Used on App Developer
- FLOAT
Value
ReadAsVoltage
- FLOAT
Ev_Start
Broadcast to all components that simulation is starting
- ULONG
ReadAsByte
Read the ADC as a byte
- BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Connection Label
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
ReadAsInt
- INT
GetValue
- FLOAT
ReadAsFloat
- FLOAT
SetValue
- FLOAT
Value
ReadAsVoltage
- FLOAT
Ev_Start
- ULONG
ReadAsByte
- BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
ReadAsInt
- INT
GetValue
- FLOAT
ReadAsFloat
- FLOAT
SetValue
- FLOAT
Value
ReadAsVoltage
- FLOAT
Ev_Start
- ULONG
ReadAsByte
- BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
ReadAsInt
- INT
GetValue
- FLOAT
ReadAsFloat
- FLOAT
SetValue
- FLOAT
Value
ReadAsVoltage
- FLOAT
Ev_Start
- ULONG
ReadAsByte
- BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
