| Author
Matrix TSL
| Version
2.0
| Category
Misc
RMT (Internal) component
Provides access to the onboard remote control (RMT) peripheral allowing for high speed data input / output without requiring bit banging from the ESP32 processor.
Please click here to download the component source project: FC_Comp_Source_RMT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RMT.fcfx
TransmitBusy
| Checks to see if the RMT channel is currently transmitting. Returns 1 if transmitting and 0 if transmission is complete.
- BYTE
SetBuffer
| Writes data to the RMT buffer
- UINT
Index
| Array index, Range: 0 - (BufferSize - 1)
- BOOL
State0
| The first state to output
- UINT
Length0
| The length of the first output state in divided clock periods
- BOOL
State1
| The second state to output
- UINT
Length1
| The length of the second output state in divided clock periods
Transmit
| Sends out the RMT data buffer.
- BYTE
WaitWhileComplete
| 0=Dont Wait, 1=Wait for TX to complete
| Initialises the RMT module ready for data to be sent or received.
Mode
| Controls if we are transmitting or receiving data
Pin
| Pin to assign the RMT functionality
Clock Divider
| Base Clock speed is 80MHz. Div by 1 = 80MHz Div by 2 = 40MHz Div by 4 = 20MHz Div by 8 = 10MHz
Mem Block Num
| Starting RMT memory block
Buffer Size
| Number of values inside the data buffer, 64 = 1 Block A buffer size of 128 would consume two sequential blocks of memory. If starting at block 1 then you can have a maximum buffer size of 512 consuming all 8 blocks.
Tx Properties
TX Loop Enable
| Allows the transmit buffer to be constantly looped.
TX Carrier Enable
| Enables a carrier frequency to be overlaid on the transmitted data
TX Idle Output
| When not transmitting should the Transmit pin be an active output?
TX Idle Level
| Sets the output state when idle.
TransmitBusy
- BYTE
SetBuffer
- UINT
Index
- BOOL
State0
- UINT
Length0
- BOOL
State1
- UINT
Length1
Transmit
- BYTE
WaitWhileComplete
Mode
Pin
Clock Divider
Mem Block Num
Buffer Size
Tx Properties
TX Loop Enable
TX Carrier Enable
TX Idle Output
TX Idle Level
TransmitBusy
- BYTE
SetBuffer
- UINT
Index
- BOOL
State0
- UINT
Length0
- BOOL
State1
- UINT
Length1
Transmit
- BYTE
WaitWhileComplete
Mode
Pin
Clock Divider
Mem Block Num
Buffer Size
Tx Properties
TX Loop Enable
TX Carrier Enable
TX Idle Output
TX Idle Level
TransmitBusy
- BYTE
SetBuffer
- UINT
Index
- BOOL
State0
- UINT
Length0
- BOOL
State1
- UINT
Length1
Transmit
- BYTE
WaitWhileComplete
Mode
Pin
Clock Divider
Mem Block Num
Buffer Size
Tx Properties
TX Loop Enable
TX Carrier Enable
TX Idle Output
TX Idle Level
