Component: SPI (CAL) (Misc)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Misc
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
Master_Enable_CS
Outputs a low signal to the chip select pin to select the remote slave device.
Slave_Uninit
Uninitialise the Slave
Prv_TextConsole
Send text to the SPI console. Exposed as part of the CAL_SPI component to allow none AutoCS pins and other.
- STRING str
- BYTE Colour
0=Default, 1=TX, 2=RX
- BYTE AppendTimestamp
0=Don't Append / 1=Do Append
Master_Transaction
Sends and receives data bytes via the SPI channel. The Buffer is to contain the data to be sent, and is overwritten by the retuning data from the device. Returns 1 for success, 0 for failure
- BYTE Buffer
- UINT Length
Number of bytes to transfer
GetValue
Reads Named property Value.
- STRING Name
- STRING Return
Slave_Init
Initialise the Slave
Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Uninit
Uninitialise the Master
Master_Byte
Sends and receives a data byte
- BYTE DataOut
GetConsoleHandle
Returns a handle to the console used by this component
- HANDLE Return
Slave_TxByte
Sets the data to be transmitted to the SPI master.
- BYTE Data
Slave_RxByte
Returns the data received from the SPI Master
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
Master_Init
Initialise the Master
GetList
returns Named property list
- STRING Name
- STRING Return
Component Enable
A global flag to enable or disable the SPI component from producing code. Useful for generating components with multiple communications options.
SPI Channel selector
MOSI
MISO
CLK
Use Auto CS
Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
CS Polarity
Options
Mode
Configures the mode of the SPI component. Currently only Master mode is supported.
Prescale
Prescale option selector
Clock Phase
Clock Polarity
Sample Point
Data bit read sample point
API
Selects the API Slave to use to send and receive real world SPI data during simulation.
Master_Enable_CS
Slave_Uninit
Prv_TextConsole
- STRING str
- BYTE Colour
Master_Transaction
- BYTE Buffer
- UINT Length
GetValue
- STRING Name
- STRING Return
Slave_Init
Master_Disable_CS
Master_Uninit
Master_Byte
- BYTE DataOut
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Slave_RxByte
SetValue
- STRING Name
- STRING Value
SetPrescaler
- BYTE Prescaler
Master_Init
GetList
- STRING Name
- STRING Return
Component Enable
MOSI
MISO
CLK
Use Auto CS
CS / SS
CS Polarity
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
API
Master_Enable_CS
Slave_Uninit
Prv_TextConsole
- STRING str
- BYTE Colour
Master_Transaction
- BYTE Buffer
- UINT Length
GetValue
- STRING Name
- STRING Return
Slave_Init
Master_Disable_CS
Master_Uninit
Master_Byte
- BYTE DataOut
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Slave_RxByte
SetValue
- STRING Name
- STRING Value
SetPrescaler
- BYTE Prescaler
Master_Init
GetList
- STRING Name
- STRING Return
Component Enable
MOSI
MISO
CLK
Use Auto CS
CS / SS
CS Polarity
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
API
Master_Enable_CS
Slave_Uninit
Prv_TextConsole
- STRING str
- BYTE Colour
Master_Transaction
- BYTE Buffer
- UINT Length
GetValue
- STRING Name
- STRING Return
Slave_Init
Master_Disable_CS
Master_Uninit
Master_Byte
- BYTE DataOut
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Slave_RxByte
SetValue
- STRING Name
- STRING Value
SetPrescaler
- BYTE Prescaler
Master_Init
GetList
- STRING Name
- STRING Return
Component Enable
MOSI
MISO
CLK
Use Auto CS
CS / SS
CS Polarity
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
API
