Component: Joystick (Sparkfun Quiic) 2D (Analog Input)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Analog Input
Joystick (Sparkfun Quiic) 2D component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to download the component source project: FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
Fc9-comp-macro.png ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
Fc9-u8-icon.png - BYTE NewAddress
Range: 8 to 119 or 0x08 - 0x77
Fc9-comp-macro.png CheckButton
Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
Fc9-comp-macro.png ReadAxis
Reads a single axis of the joystick and returns as a signed integer value.
Fc9-u8-icon.png - BYTE Axis
Range 0-1 Where 0=X, 1=Y
Fc9-bool-icon.png - BOOL Type
0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png SimMoveThumbStick
Fc9-f32-icon.png - FLOAT X
Fc9-f32-icon.png - FLOAT Y
Fc9-h32-icon.png - HANDLE Component
Fc9-comp-macro.png ReadButton
Checks to see if the button is currently pressed
Fc9-comp-macro.png Initialise
Initialises the I2C bus ready for communications with the module.
Fc9-type-7-icon.png Return To Center
Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Fc9-conn-icon.png Limits
Fc9-type-15-icon.png X Min
Fc9-type-15-icon.png X Max
Fc9-type-21-icon.png Device Address
Fc9-conn-icon.png Theme
Fc9-type-1-icon.png Box Colour
Fc9-type-1-icon.png Shaft Colour
Fc9-type-1-icon.png Knob Colour
Fc9-type-16-icon.png Style
Fc9-type-12-icon.png Style
Outline line style
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
Outline line style
Channel selection
Outline line style
Channel selection
Outline line style
Channel selection
