Component: Switch Extension ()
| Author | |
| Category |
Switch Extension component
An extension to the default switch Overlays the switch with a mesh
Please click here to download the component source project: FC_Comp_Source_Switch_ext.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_ext.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
| Properties |
| Properties |
| Properties |
| Properties |
