Component: Thermistor Template (Sensors)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix
Category Sensors
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Please click here to download the component source project: FC_Comp_Source_Thermistor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C. EBM003 Example
GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT Return
SetChannel
Set the ADC Channel
- INT ChannelID
GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT Return
CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
- UINT ADCValue
ADC Reading to be converted
- INT Return
GetADCValue
Returns the Raw ADC value from the Analogue Channel
SetTemperature
Simulation macro that sets the internal ADC value to the appropriate value for a given temperature. This allows all internal systems of the sensor to be simulated.
- FLOAT Temperature
The temperature in C - restricted to -25 to +125 range
ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
ADC Bit Resolution
Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
-25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
Conversion speed
Acquisition cycles
VRef option
- INT Return
SetChannel
Set the ADC Channel
- INT ChannelID
GetRealTemperature
- FLOAT Return
- UINT ADCValue
- INT Return
GetADCValue
SetTemperature
- FLOAT Temperature
ADC Channel
Wiring
ADC Bit Resolution
Resistor Value
0C Thermistor Value
Conversion speed
Acquisition cycles
VRef option
- INT Return
SetChannel
Set the ADC Channel
- INT ChannelID
GetRealTemperature
- FLOAT Return
- UINT ADCValue
- INT Return
GetADCValue
SetTemperature
- FLOAT Temperature
ADC Channel
Wiring
ADC Bit Resolution
Resistor Value
0C Thermistor Value
Conversion speed
Acquisition cycles
VRef option
- INT Return
SetChannel
Set the ADC Channel
- INT ChannelID
GetRealTemperature
- FLOAT Return
- UINT ADCValue
- INT Return
GetADCValue
SetTemperature
- FLOAT Temperature
ADC Channel
Wiring
ADC Bit Resolution
Resistor Value
0C Thermistor Value
Conversion speed
Acquisition cycles
VRef option
