Component: UART (CAL) (Misc)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.2
Category Misc
UART component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Please click here to download the component source project: FC_Comp_Source_UART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART.fcfx
ControlPin
Allows direct control over the TX and RTS pins Also allows for reading of the state of the RX and CTS pins. Only available when the UART is uninitialised.
- BYTE Pin
0=TX, 1=RX, 2=RTS, 3=CTS
- BYTE State
SendString
Transmits a string of bytes via the UART peripheral
- STRING Data
Data String to transmit
UpdateBaud
Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
- BYTE new_baud
TestProperty
A simple macro to allow us to test the value of a single property during runtime.
- BYTE Property
0=UseTX, 1=UseRX, 2=UseFlowControl
SendNumber
Transmits a numeric value as an ASCII string
- LONG Number
Numeric value to send
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Prv_SimShowWaveform
- BYTE TXRX
- UINT Data
Receive
Receive a Character
- BYTE Timeout
Period to wait for the character to be received
- INT Return
Send
Send the Character
- UINT Char
The Character to send
GetConsoleHandle
- HANDLE Return
SendByteArray
Transmits an array of bytes via the UART peripheral
- BYTE Data
Data to transmit
- BYTE NumBytes
Number of bytes to send from the array
Init
Initialize the component with the specified properties
Delay
Software UART Bit Delay
SetValue
set Value of Named property
- STRING Name
- STRING Value
Uninit
Un-initialize the UART and release the resources
GetList
Gets Named property List
- STRING Name
- STRING Return
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
- BYTE NumBytes
Maximum number of bytes to try and receive
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveString
Receives a string of bytes and returns the number of bytes received.
- STRING StringData
- BYTE NumBytes
- BYTE Timeout
Component Enable
A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
Transmit
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
Receive
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
Number of data bits
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
Automatically echoes back any received data when enabled by re-transmitting the received byte.
Interrupt
Automatic receive interrupt mode enable or disable. Used on components such as the GSM or GPS where data can come in at any time. Software channel is disabled when interrupt is enabled, for interrupt with a software channel use an I/O edge triggered interrupt.
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
ControlPin
- BYTE Pin
- BYTE State
SendString
- STRING Data
UpdateBaud
- BYTE new_baud
TestProperty
- BYTE Property
SendNumber
- LONG Number
GetValue
- STRING Name
- STRING Return
Prv_SimShowWaveform
- BYTE TXRX
- UINT Data
Receive
Receive a Character
- BYTE Timeout
- INT Return
Send
Send the Character
- UINT Char
GetConsoleHandle
- HANDLE Return
SendByteArray
- BYTE Data
Data to transmit
- BYTE NumBytes
Init
Delay
SetValue
- STRING Name
- STRING Value
Uninit
GetList
- STRING Name
- STRING Return
ReceiveByteArray
- BYTE Data
- BYTE NumBytes
- BYTE Timeout
ReceiveString
- STRING StringData
- BYTE NumBytes
- BYTE Timeout
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
ControlPin
- BYTE Pin
- BYTE State
SendString
- STRING Data
UpdateBaud
- BYTE new_baud
TestProperty
- BYTE Property
SendNumber
- LONG Number
GetValue
- STRING Name
- STRING Return
Prv_SimShowWaveform
- BYTE TXRX
- UINT Data
Receive
Receive a Character
- BYTE Timeout
- INT Return
Send
Send the Character
- UINT Char
GetConsoleHandle
- HANDLE Return
SendByteArray
- BYTE Data
Data to transmit
- BYTE NumBytes
Init
Delay
SetValue
- STRING Name
- STRING Value
Uninit
GetList
- STRING Name
- STRING Return
ReceiveByteArray
- BYTE Data
- BYTE NumBytes
- BYTE Timeout
ReceiveString
- STRING StringData
- BYTE NumBytes
- BYTE Timeout
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
ControlPin
- BYTE Pin
- BYTE State
SendString
- STRING Data
UpdateBaud
- BYTE new_baud
TestProperty
- BYTE Property
SendNumber
- LONG Number
GetValue
- STRING Name
- STRING Return
Prv_SimShowWaveform
- BYTE TXRX
- UINT Data
Receive
Receive a Character
- BYTE Timeout
- INT Return
Send
Send the Character
- UINT Char
GetConsoleHandle
- HANDLE Return
SendByteArray
- BYTE Data
Data to transmit
- BYTE NumBytes
Init
Delay
SetValue
- STRING Name
- STRING Value
Uninit
GetList
- STRING Name
- STRING Return
ReceiveByteArray
- BYTE Data
- BYTE NumBytes
- BYTE Timeout
ReceiveString
- STRING StringData
- BYTE NumBytes
- BYTE Timeout
Component Enable
Transmit
Use TX
TX
Receive
Use RX
RX
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
Number of data bits
Echo
Interrupt
Console Format
Console Columns
Data Source
