Component: ADC Template 2D (Analog Input)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Analog Input
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
Please click here to download the component source project: FC_Comp_Source_adc_Base_2dgdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base_2dgdi.fcfx
RawSampleInt
Background call to read the ADC at full bit depth Call Enable() first
RawAverageByte
Background call to read the ADC as a byte average sample over time Call Enable() before this
- BYTE NumSamples
- BYTE DelayUs
Number of micro seconds in between taking each sample
GetSampleBits
Gets the number of bits per sample
GetString
Reads the ADC as a direct voltage and returns as a string
- STRING Return
GetAverageByte
Function call to read the ADC as a byte average sample over time
- BYTE NumSamples
- BYTE DelayUs
RawAverageInt
Background call to read the ADC as a full width average sample over time Call Enable() before this
- BYTE NumSamples
- BYTE DelayUs
- INT Return
GetSpeedFilter
Gets the Conversion speed filter string Use in Component.Property.SetFilter()
- STRING Return
GetAverageInt
Function call to read the ADC as a full width average sample over time
- BYTE NumSamples
- BYTE DelayUs
SetProperties
Set the VRef options and voltage, ConvSpeed and AcqTime for the ADC component.
- INT VRef10Ms
Voltage Reference x10 mV - Default 500 = 5V
- BOOL VRefOpt
External VRef 0=Disabled, 1=Enabled
- INT ConvSpdOpt
Conversion Speed Setting - Refer to numbered list
- INT Aquisitions
Aquisition time in micro seconds to precharge before sampling
GetVoltage
- FLOAT Return
RawEnable
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
SetChannel
Sets the channel ID for the component
- INT ChannelId
Chaannel starting at 0, -1 is unconnected
RawSampleByte
Background call to read the ADC as a byte Call Enable() before this
GetInt
Blocking call to read the ADC at full bit depth
RawDisable
Disables the previously enabled ADC channel and converts back to digital mode.
GetByte
Blocking call to read the ADC as a byte
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
RawSampleInt
RawAverageByte
- BYTE NumSamples
- BYTE DelayUs
GetSampleBits
GetString
- STRING Return
GetAverageByte
- BYTE NumSamples
- BYTE DelayUs
RawAverageInt
- BYTE NumSamples
- BYTE DelayUs
- INT Return
GetSpeedFilter
- STRING Return
GetAverageInt
- BYTE NumSamples
- BYTE DelayUs
SetProperties
- INT VRef10Ms
- BOOL VRefOpt
- INT ConvSpdOpt
- INT Aquisitions
GetVoltage
- FLOAT Return
RawEnable
SetChannel
- INT ChannelId
RawSampleByte
GetInt
RawDisable
GetByte
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
RawSampleInt
RawAverageByte
- BYTE NumSamples
- BYTE DelayUs
GetSampleBits
GetString
- STRING Return
GetAverageByte
- BYTE NumSamples
- BYTE DelayUs
RawAverageInt
- BYTE NumSamples
- BYTE DelayUs
- INT Return
GetSpeedFilter
- STRING Return
GetAverageInt
- BYTE NumSamples
- BYTE DelayUs
SetProperties
- INT VRef10Ms
- BOOL VRefOpt
- INT ConvSpdOpt
- INT Aquisitions
GetVoltage
- FLOAT Return
RawEnable
SetChannel
- INT ChannelId
RawSampleByte
GetInt
RawDisable
GetByte
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
RawSampleInt
RawAverageByte
- BYTE NumSamples
- BYTE DelayUs
GetSampleBits
GetString
- STRING Return
GetAverageByte
- BYTE NumSamples
- BYTE DelayUs
RawAverageInt
- BYTE NumSamples
- BYTE DelayUs
- INT Return
GetSpeedFilter
- STRING Return
GetAverageInt
- BYTE NumSamples
- BYTE DelayUs
SetProperties
- INT VRef10Ms
- BOOL VRefOpt
- INT ConvSpdOpt
- INT Aquisitions
GetVoltage
- FLOAT Return
RawEnable
SetChannel
- INT ChannelId
RawSampleByte
GetInt
RawDisable
GetByte
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
