| Author
Matrix Ltd
| Version
1.0
| Category
Third Party
FTDI (FTD2XX) component
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. For more details refer to the D2XX_Programmers_Guide from FTDI.
Please click here to download the component source project: FC_Comp_Source_ftd2xx_232.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_ftd2xx_232.fcsx
FT_GetStatus
| Gets the device status including number of characters in the receive queue, number of characters in the transmit queue, and the current event status.
- LONG
Handle
| Handle of the device.
- LONG
RxQueueLength
| Pointer to a variable of type DWORD which receives the number of characters in the receive queue.
- LONG
TxQueueLength
| Pointer to a variable of type DWORD which receives the number of characters in the transmit queue.
- LONG
EventStatus
| Pointer to a variable of type DWORD which receives the current state of the event status.
- BYTE
FT_ClrRts
| This function clears the Request To Send (RTS) control signal.
- LONG
Handle
FT_Write
| Write data to the device.
- LONG
Handle
- BYTE
Buffer
| Pointer to the buffer that contains the data to be written to the device.
- ULONG
Bytes
| Number of bytes to write to the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes written to the device.
- BYTE
FT_Read
| Read data from the device.
- LONG
Handle
- BYTE
Buffer
| Pointer to the buffer that receives the data from the device.
- ULONG
Bytes
| Number of bytes to be read from the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes read from the device.
- BYTE
FT_SetFlowControl
| This function sets the flow control for the device.
- LONG
Handle
- UINT
FlowControl
| Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF
- BYTE
Xon
| Character used to signal Xon. Only used if flow control is Xon/Xoff
- BYTE
Xoff
| Character used to signal Xoff. Only used if flow control is Xon/Xoff
- BYTE
FT_GetModemStatus
| Gets the modem status and line status from the device.
- LONG
Handle
- LONG
ModemStatus
| Pointer to a variable of type DWORD which receives the modem status and line status from the device.
- BYTE
FT_SetBreakOn
| Sets the BREAK condition for the device.
- LONG
Handle
- BYTE
FT_CreateDeviceInfoList
| This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices.
- LONG
DevCount
| Unsigned long array used to store the number of devices connected
- BYTE
FT_SetTimeouts
| This function sets the read and write timeouts for the device.
- LONG
Handle
- LONG
ReadTimeout
| Read timeout in milliseconds.
- LONG
WriteTimeout
| Write timeout in milliseconds.
- BYTE
FT_SetBitMode
| Enables different chip modes.
- LONG
Handle
- BYTE
Mask
| Required value for bit mode mask. This sets up which bits are inputs and outputs. A bit value of 0 sets the corresponding pin to an input, a bit value of 1 sets the corresponding pin to an output.
- BYTE
Mode
| 0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO
- BYTE
FT_SetRts
| This function sets the Request To Send (RTS) control signal.
- LONG
Handle
- BYTE
FT_GetDeviceInfoDetail
| This function returns an entry from the device information list.
- ULONG
Index
| Index of the entry in the device info list.
- ULONG
Flags
| Pointer to unsigned long to store the flag value.
- ULONG
Type
| Pointer to unsigned long to store device type.
- ULONG
ID
| Pointer to unsigned long to store device ID.
- ULONG
LocID
| Pointer to unsigned long to store the device location ID.
- BYTE
SerNum
| Pointer to buffer to store device serial number as a null terminated string
- BYTE
Descript
| Pointer to buffer to store device description as a null-terminated string
- LONG
TempHandle
| Pointer to a variable of type FT_HANDLE where the handle will be stored
- BYTE
FT_Close
| Close an open device.
- LONG
Handle
- BYTE
FT_ClrDtr
| This function clears the Data Terminal Ready (DTR) control signal.
- LONG
Handle
- BYTE
FT_Purge
| This function purges receive and transmit buffers in the device.
- LONG
Handle
- LONG
Mask
| Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both
- BYTE
FT_GetQueueStatus
| Gets the number of bytes in the receive queue.
- LONG
Handle
- LONG
RxQueueLength
| Pointer to a variable of type DWORD which receives the number of bytes in the receive queue.
- BYTE
FT_SetDataCharacteristics
| This function sets the data characteristics for the device.
- LONG
Handle
- BYTE
WordLength
| Number of bits per word - Must be 7 or 8
- BYTE
StopBits
| Number of stop bits - Must be 1 or 2
- BYTE
Parity
| Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space
- BYTE
FT_SetBreakOff
| Resets the BREAK condition for the device.
- LONG
Handle
- BYTE
FT_SetDivisor
| This function sets the baud rate for the device. It is used to set non-standard baud rates.
- LONG
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
- LONG
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
| This function sets the Data Terminal Ready (DTR) control signal.
- LONG
Handle
- BYTE
FT_Open
| Open the device and return a handle which will be used for subsequent accesses.
- INT
Device
| Index of the device to open. Indices are 0 based.
- LONG
ft_Handle
| Pointer to a variable of type FT_HANDLE where the handle will be stored. This handle must be used to access the device.
- BYTE
ScanFor232
| Scans for a FTDI D2XX device, returnes true if at least one device was found.
- BOOL
FT_ResetDevice
| This function sends a reset command to the device.
- LONG
Handle
- BYTE
FT_SetChars
| This function sets the special characters for the device.
- LONG
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
| 0 if event character disabled, non-zero otherwise.
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
| 0 if error character disabled, non-zero otherwise.
- BYTE
| A text label for the component's panel component.
FT_GetStatus
- LONG
Handle
- LONG
RxQueueLength
- LONG
TxQueueLength
- LONG
EventStatus
- BYTE
FT_ClrRts
- LONG
Handle
FT_Write
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_Read
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_SetFlowControl
- LONG
Handle
- UINT
FlowControl
- BYTE
Xon
- BYTE
Xoff
- BYTE
FT_GetModemStatus
- LONG
Handle
- LONG
ModemStatus
- BYTE
FT_SetBreakOn
- LONG
Handle
- BYTE
- LONG
DevCount
- BYTE
FT_SetTimeouts
- LONG
Handle
- LONG
ReadTimeout
- LONG
WriteTimeout
- BYTE
FT_SetBitMode
- LONG
Handle
- BYTE
Mask
- BYTE
Mode
- BYTE
FT_SetRts
- LONG
Handle
- BYTE
- ULONG
Index
- ULONG
Flags
- ULONG
Type
- ULONG
ID
- ULONG
LocID
- BYTE
SerNum
- BYTE
Descript
- LONG
TempHandle
- BYTE
FT_Close
- LONG
Handle
- BYTE
FT_ClrDtr
- LONG
Handle
- BYTE
FT_Purge
- LONG
Handle
- LONG
Mask
- BYTE
FT_GetQueueStatus
- LONG
Handle
- LONG
RxQueueLength
- BYTE
- LONG
Handle
- BYTE
WordLength
- BYTE
StopBits
- BYTE
Parity
- BYTE
FT_SetBreakOff
- LONG
Handle
- BYTE
FT_SetDivisor
- LONG
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
- LONG
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
- LONG
Handle
- BYTE
FT_Open
- INT
Device
- LONG
ft_Handle
- BYTE
ScanFor232
- BOOL
FT_ResetDevice
- LONG
Handle
- BYTE
FT_SetChars
- LONG
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
- BYTE
FT_GetStatus
- LONG
Handle
- LONG
RxQueueLength
- LONG
TxQueueLength
- LONG
EventStatus
- BYTE
FT_ClrRts
- LONG
Handle
FT_Write
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_Read
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_SetFlowControl
- LONG
Handle
- UINT
FlowControl
- BYTE
Xon
- BYTE
Xoff
- BYTE
FT_GetModemStatus
- LONG
Handle
- LONG
ModemStatus
- BYTE
FT_SetBreakOn
- LONG
Handle
- BYTE
- LONG
DevCount
- BYTE
FT_SetTimeouts
- LONG
Handle
- LONG
ReadTimeout
- LONG
WriteTimeout
- BYTE
FT_SetBitMode
- LONG
Handle
- BYTE
Mask
- BYTE
Mode
- BYTE
FT_SetRts
- LONG
Handle
- BYTE
- ULONG
Index
- ULONG
Flags
- ULONG
Type
- ULONG
ID
- ULONG
LocID
- BYTE
SerNum
- BYTE
Descript
- LONG
TempHandle
- BYTE
FT_Close
- LONG
Handle
- BYTE
FT_ClrDtr
- LONG
Handle
- BYTE
FT_Purge
- LONG
Handle
- LONG
Mask
- BYTE
FT_GetQueueStatus
- LONG
Handle
- LONG
RxQueueLength
- BYTE
- LONG
Handle
- BYTE
WordLength
- BYTE
StopBits
- BYTE
Parity
- BYTE
FT_SetBreakOff
- LONG
Handle
- BYTE
FT_SetDivisor
- LONG
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
- LONG
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
- LONG
Handle
- BYTE
FT_Open
- INT
Device
- LONG
ft_Handle
- BYTE
ScanFor232
- BOOL
FT_ResetDevice
- LONG
Handle
- BYTE
FT_SetChars
- LONG
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
- BYTE
FT_GetStatus
- LONG
Handle
- LONG
RxQueueLength
- LONG
TxQueueLength
- LONG
EventStatus
- BYTE
FT_ClrRts
- LONG
Handle
FT_Write
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_Read
- LONG
Handle
- BYTE
Buffer
- ULONG
Bytes
- ULONG
Count
- BYTE
FT_SetFlowControl
- LONG
Handle
- UINT
FlowControl
- BYTE
Xon
- BYTE
Xoff
- BYTE
FT_GetModemStatus
- LONG
Handle
- LONG
ModemStatus
- BYTE
FT_SetBreakOn
- LONG
Handle
- BYTE
- LONG
DevCount
- BYTE
FT_SetTimeouts
- LONG
Handle
- LONG
ReadTimeout
- LONG
WriteTimeout
- BYTE
FT_SetBitMode
- LONG
Handle
- BYTE
Mask
- BYTE
Mode
- BYTE
FT_SetRts
- LONG
Handle
- BYTE
- ULONG
Index
- ULONG
Flags
- ULONG
Type
- ULONG
ID
- ULONG
LocID
- BYTE
SerNum
- BYTE
Descript
- LONG
TempHandle
- BYTE
FT_Close
- LONG
Handle
- BYTE
FT_ClrDtr
- LONG
Handle
- BYTE
FT_Purge
- LONG
Handle
- LONG
Mask
- BYTE
FT_GetQueueStatus
- LONG
Handle
- LONG
RxQueueLength
- BYTE
- LONG
Handle
- BYTE
WordLength
- BYTE
StopBits
- BYTE
Parity
- BYTE
FT_SetBreakOff
- LONG
Handle
- BYTE
FT_SetDivisor
- LONG
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
- LONG
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
- LONG
Handle
- BYTE
FT_Open
- INT
Device
- LONG
ft_Handle
- BYTE
ScanFor232
- BOOL
FT_ResetDevice
- LONG
Handle
- BYTE
FT_SetChars
- LONG
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
- BYTE
