| Author
Matrix Ltd
| Version
1.1
| Category
LED
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_bicolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_bicolour.fcfx
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LED Resistor Calculator Tool
LEDOff
| Switches off the LED
LEDSetState
| Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2
- BYTE
State
| 0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High
LEDOneOn
| Switches on LED one
LEDTwoOn
| Switches on LED two
Pin
| LED Pin 1
Pin2
| LED Pin 2
Color
| The color of the LED when pin1 is turned on and pin2 is turned off.
Color2
| The color of the LED when pin1 is turned off and pin2 is turned on.
Trim Leads
| Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Color
| Color of the labels text.
Scale
| Sets the basic size (text height) of the labels.
Follow Zoom
| Whether labels get bigger and smaller when the panel is zoomed in and out.
LEDOff
LEDSetState
- BYTE
State
LEDOneOn
| Switches on LED one
LEDTwoOn
| Switches on LED two
Pin
| LED Pin 1
Pin2
| LED Pin 2
Color
Color2
Trim Leads
Color
Scale
Follow Zoom
LEDOff
LEDSetState
- BYTE
State
LEDOneOn
| Switches on LED one
LEDTwoOn
| Switches on LED two
Pin
| LED Pin 1
Pin2
| LED Pin 2
Color
Color2
Trim Leads
Color
Scale
Follow Zoom
LEDOff
LEDSetState
- BYTE
State
LEDOneOn
| Switches on LED one
LEDTwoOn
| Switches on LED two
Pin
| LED Pin 1
Pin2
| LED Pin 2
Color
Color2
Trim Leads
Color
Scale
Follow Zoom
