Component: Hydro Encryption (Comms: Networking)
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Author
Category Comms: Networking
Hydro Encryption component
A cipher suite to enable encryption and decryption of data messages, based on libhydrogen.
Please click here to download the component source project: FC_Comp_Source_libhydrogen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_libhydrogen.fcfx
Fc9-comp-macro.png sign_create
Computes a signature for a message using the secret key. Returns 0 if successful.
Fc9-u8-icon.png - BYTE signature
Buffer to receive the signature. Must be 64 bytes.
Fc9-u8-icon.png - BYTE message
Buffer containing the data to sign
Fc9-u16-icon.png - UINT message_size
Byte count of the message
Fc9-u8-icon.png - BYTE secret_key
Secret/Private key to be used.Size is 64 bytes.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png secretbox_keygen
Creates a secret key suitable for use with the secretbox functions. You must provide a 32 byte array for the key.
Fc9-u8-icon.png - BYTE key
Fc9-comp-macro.png hash_with_key
Creates a hash fingerprint of the data, using the given key. Returns 0 if successful.
Fc9-u8-icon.png - BYTE hash
Buffer for the hash. Size >=32 makes it practically impossible for two messages to produce the same fingerprint.
Fc9-u8-icon.png - BYTE data
The data buffer to be processed
Fc9-u16-icon.png - UINT size
Byte count of the data to be processed
Key to be used
Fc9-comp-macro.png sign_verify
Verify the signature of a mesasge using the public key. Returns 0 if successful.
Fc9-u8-icon.png - BYTE public_key
Public key to be used.Size is 32 bytes.
Fc9-comp-macro.png init
Initialisation function. To be called at the very start of your program.
Fc9-comp-macro.png sign_keygen
Creates Private and Public key pair to sign and verify messages. Returns 0 if successful.
Fc9-u8-icon.png - BYTE Secret
Buffer to receive the Private/Secret Key. Buffer size must be 64 bytes
Fc9-u8-icon.png - BYTE Public
Buffer to receive the Public key. Buffer size must be 32 bytes
Fc9-comp-macro.png secretbox_encrypt
Encrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
Buffer containing the message to be encrypted.
Fc9-u16-icon.png - UINT length
The length (byte count) of the message
Fc9-u16-icon.png - UINT ID
Message ID. Can be 0
The secret key
Fc9-u8-icon.png - BYTE ciphertext
Buffer for ciphertext output. Buffer size must be at least length + 36
Fc9-comp-macro.png hash_keygen
Creates a secret key suitable for use with the hash_hash function. You must provide a 32 byte array for the key.
Fc9-comp-macro.png secretbox_decrypt
Decrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
Buffer for the decrypted message. Size must be at least length - 36
The length (byte count) of the ciphertext
Message ID. Must match with the original message ID. Can be 0
The secret key
Buffer containing the ciphertext to be decrypted.
Fc9-comp-macro.png hash_without_key
Creates a hash fingerprint of the data, which will always have the same fingerprint, similar to the MD5 or SHA-1 Returns 0 if successful.
Data buffer to be processed
Byte count of data to be processed
Key to be used
The secret key
The secret key
Key to be used
The secret key
The secret key
Key to be used
The secret key
The secret key
