Component: MIAC GSM (MIAC: Addon Modules)
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Author
Category MIAC: Addon Modules
MIAC GSM component
GSM Addon for MIAC System.
Please click here to download the component source project: FC_Comp_Source_ma_gsm.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ma_gsm.fcfx
GSM_SetStart
Sets the state of the GSM module Start pin. (Low level GSM interface)
- BYTE State
GSM_CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
GSM_SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
GSM_SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
- STRING Number
- STRING Message
GSM_SendCommand
Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
GSM_GetCharCount
Returns the number of characters waiting to be read from the receive buffer. (Low level GSM interface)
GSM_CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
GSM_HangUpCall
Ends a voice based call. Returns 0 for success and 255 for failure.
MIAC_Module_GetData
- BYTE Index
GSM_SetReset
Sets the state of the GSM module Reset pin. State = 0 will hold the module in the reset state (Low level GSM interface)
- BYTE State
GSM_DialNumber
Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
- STRING Number
GSM_StringReceive
Attempts to receive a string from the GSM modem. Returns 1 if successful, 0 on timeout
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
GSM_AnswerIncomingCall
Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
GSM_SetRTS
Sets the state of the GSM module RTS pin. (Low level GSM interface)
- BYTE State
MIAC_Module_PushData
- BYTE Data
GSM_Initialize
Resets and restarts the GSM module Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
GSM_SendCharacter
Sends the byte character to the GSM module. (Low level GSM interface)
- BYTE Byte
GSM_ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
- STRING Return
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
GSM_GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
- STRING Return
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
GSM_GetStatus
Returns status bits from the GSM module. Bit 6 = CTS, Bit 12 = STATUS (LED), Bit 13 = RING (Low level GSM interface)
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
GSM_GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
- STRING Return
DigitalInput
Read the value of a terminal
- BYTE Terminal
GSM_GetCharacter
Returns the next character waiting to be read from the receive buffer. (Low level GSM interface)
Module Type
Module Address
Script Count
Maximum number of scripts to store in the device's ROM
Script1
ASCII based AT command data stored in ROM and used when sending script 1
Expect Echo
GSM_SetStart
- BYTE State
GSM_SendScript
- BYTE idx
GSM_SendTextMessage
- STRING Number
- STRING Message
GSM_SendCommand
- STRING Command
- BYTE SendCR
GSM_GetCharCount
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
GSM_HangUpCall
MIAC_Module_GetData
- BYTE Index
GSM_SetReset
- BYTE State
GSM_DialNumber
- STRING Number
GSM_StringReceive
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
GSM_SetRTS
- BYTE State
- BYTE Data
GSM_Initialize
GSM_SendCharacter
- BYTE Byte
GSM_ReadString
- BYTE NumBytes
- STRING Return
DigitalOutput
- BYTE Terminal
- BYTE Value
GSM_GetTextString
- BYTE NumBytes
- STRING Return
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
GSM_GetStatus
AnalogInput
- BYTE Terminal
GSM_GetTextNumber
- BYTE NumBytes
- STRING Return
DigitalInput
- BYTE Terminal
GSM_GetCharacter
Module Type
Module Address
Script Count
Script1
Expect Echo
GSM_SetStart
- BYTE State
GSM_SendScript
- BYTE idx
GSM_SendTextMessage
- STRING Number
- STRING Message
GSM_SendCommand
- STRING Command
- BYTE SendCR
GSM_GetCharCount
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
GSM_HangUpCall
MIAC_Module_GetData
- BYTE Index
GSM_SetReset
- BYTE State
GSM_DialNumber
- STRING Number
GSM_StringReceive
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
GSM_SetRTS
- BYTE State
- BYTE Data
GSM_Initialize
GSM_SendCharacter
- BYTE Byte
GSM_ReadString
- BYTE NumBytes
- STRING Return
DigitalOutput
- BYTE Terminal
- BYTE Value
GSM_GetTextString
- BYTE NumBytes
- STRING Return
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
GSM_GetStatus
AnalogInput
- BYTE Terminal
GSM_GetTextNumber
- BYTE NumBytes
- STRING Return
DigitalInput
- BYTE Terminal
GSM_GetCharacter
Module Type
Module Address
Script Count
Script1
Expect Echo
GSM_SetStart
- BYTE State
GSM_SendScript
- BYTE idx
GSM_SendTextMessage
- STRING Number
- STRING Message
GSM_SendCommand
- STRING Command
- BYTE SendCR
GSM_GetCharCount
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
GSM_HangUpCall
MIAC_Module_GetData
- BYTE Index
GSM_SetReset
- BYTE State
GSM_DialNumber
- STRING Number
GSM_StringReceive
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
GSM_SetRTS
- BYTE State
- BYTE Data
GSM_Initialize
GSM_SendCharacter
- BYTE Byte
GSM_ReadString
- BYTE NumBytes
- STRING Return
DigitalOutput
- BYTE Terminal
- BYTE Value
GSM_GetTextString
- BYTE NumBytes
- STRING Return
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
GSM_GetStatus
AnalogInput
- BYTE Terminal
GSM_GetTextNumber
- BYTE NumBytes
- STRING Return
DigitalInput
- BYTE Terminal
GSM_GetCharacter
Module Type
Module Address
Script Count
Script1
Expect Echo
