Component: MIAC Zigbee Coordinator (MIAC: Addon Modules)
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Author
Category MIAC: Addon Modules
MIAC Zigbee Coordinator component
MIAC Zigbee Coordinator Addon component for MIAC System. Add the Zigbee component to the panel to add functionality.
Please click here to download the component source project: FC_Comp_Source_ma_zigbee_c.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ma_zigbee_c.fcfx
MIAC_Module_RD
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Return
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
MIAC_Module_PushData
- BYTE Data
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
Initialize
Forces a software reset on the module
DigitalInput
Read the value of a terminal
- BYTE Terminal
Module Type
Module Address
MIAC_Module_RD
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Return
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
- BYTE Data
DigitalOutput
- BYTE Terminal
- BYTE Value
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
AnalogInput
- BYTE Terminal
Initialize
DigitalInput
- BYTE Terminal
Module Type
Module Address
MIAC_Module_RD
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Return
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
- BYTE Data
DigitalOutput
- BYTE Terminal
- BYTE Value
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
AnalogInput
- BYTE Terminal
Initialize
DigitalInput
- BYTE Terminal
Module Type
Module Address
MIAC_Module_RD
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Return
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
LED_Control
- BYTE State
- BYTE Data
DigitalOutput
- BYTE Terminal
- BYTE Value
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
AnalogInput
- BYTE Terminal
Initialize
DigitalInput
- BYTE Terminal
Module Type
Module Address
