| Author | Matrix Ltd |
| Version | 1.2 |
| Category |  |
Switch (Slide, PCB) component
Subminiature slide switch with black tang, PCB mount.
Please click here to download the component source project: FC_Comp_Source_sw_slide_sub_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_slide_sub_pcb.fcfx
 Switch
Switch
(5V / 11K) * 10K = 4.54545V
|   | Properties |
|   | Connections |
|   | Connection |
| The chip pin to which this switch is connected. |
|   | Polarity |
| Sets whether the pin should go high or low when the switch is activated. |
|   | Debounce (ms) |
| Time in milliseconds allowed for the chip pin to stabilise following a change of state.  NB) Debouncing is only used when reading the switch state using the component macros.        Chip pin is NOT debounced. |
|   | Simulation |
|   | Operation |
| Operation of the switch. Latching - the switch toggles state with each mouse click, and stays in position when released. Momentary - the switch turns on when the mouse is clicked, and turns off when the mouse is released. |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
