| Author | Matrix Ltd |
| Version | 1.1 |
| Category |  |
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang.  Pins for PCB mounting.
Please click here to download the component source project: FC_Comp_Source_sw_toggle_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_pcb.fcfx
 Switch
Switch
(5V / 11K) * 10K = 4.54545V
|   | Properties |
|   | Connections |
|   | Connection |
| Chip pin to which this switch is connected. |
|   | Polarity |
| Sets whether the pin should go high or low when the switch is activated. |
|   | Debounce (ms) |
| Time in milliseconds allowed for the pin to stabilise following a change of state.  NB) Debouncing is only used when reading the switch state with the component macros.        Chip pin is NOT debounced. |
|   | Simulation |
|   | Operation |
| Latching - click the switch to turn it on, click again to turn it off. Momentary - click the switch to turn it on, release the mouse to turn it off. |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
|   | Properties |
|   | Connections |
|   | Connection |
|   | Polarity |
|   | Debounce (ms) |
|   | Simulation |
|   | Operation |
