Component: API (ECIO28P) (API Slave Devices)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API (ECIO28P) component
Connects to an ECIO28P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ECIO28P_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ECIO28P_API_Comp.fcfx
The App Developer (ECIO28P) component allows an ECIO28P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO28P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ECIO28P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO28P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Device Port Pin A0 A1 A2 A3 A4 A5 B0 B1 B2 B3 B4 B5 B6 B7 C0 C1 C2 C6 C7
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12
Device Port Pin A0 A1 A2 A3 A5 B2 B3 B1 B4 B0
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK UART RX UART TX PWM 0 PWM 1
Device Port Pin B0 B1 C7 B0 B1 C7 C6 C2 C1
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5 (the LED pin).
ECIO28P App Developer Example
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
ECIO App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
ECIO App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
ECIO App Developer Slave UART Demo
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-18
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-12
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTInitialise
- BYTE Channel
UARTCheckRX
- BYTE Channel
RegisterWrite
Writes to one of the registers on-board the device
- UINT RegisterAddress
The address of the register
- BYTE Data
The data value to assign to the register
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
RegisterRead
Read one of the registers on-board the device
I2CRestart
- BYTE Channel
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-5
- BYTE Duty
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-12
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
IOSetOutputPin
- BYTE Pin
Range: 0-18
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
Auto Detect Port
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
