| Author
Matrix TSL
| Version
1.0
| Category
Runtime Tools
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
Please click here to download the component source project: FC_Comp_Source_EventLog.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EventLog.fcfx
LogEvent
| Allows an event string to be logged
- STRING
LogString
Log To Console
Log To File
Include Timestamp
| Controls if a timestamp is appended to the start of the log string. Yes: Add timestamp to log string No: Leave log string as is
Console Properties
Console Name
Clear On Init
| Selects if the contents of the console are maintained or wiped on runtime start. Yes: Console is automatically cleared No: Console is maintained and appended
File Properties
Log File
| File to store the log data. Default: $(srcdir)log.txt $(srcdir) specifies the directory containing your Flowcode project file. log.txt specifies a file named log.txt If the file does not exist then it will be automatically created for you.
Clear On Init
| Selects if the contents of the log file are maintained or wiped on runtime start. Yes: Log file is automatically cleared No: Log file is maintained and appended
Timestamp Properties
TimeStamp
US Date Format
| Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
