Component: Gearbox (Mechatronics)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Category Mechatronics
Gearbox component
A simple component to couple together two rotating shafts via a gearbox. The gearbox can be used to scale the input rotational speed and optionally reverse the output direction.
Please click here to download the component source project: FC_Comp_Source_GearBox.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GearBox.fcfx
Rotate
- FLOAT Angle
Geabox
Gear Ratio
Sets the input to output gear ratio. For example a ratio of 2:1 would be 0.5, a ratio of 1:5 would be 5.0. Negative ratio values allow the input direction to be reversed.
Input
Input connection for example a motor or other active component or primitive.
Output
Output connection for example a primitive or a component such as a linear slide or gearbox.
Input Offset
Distance along the shaft from the center of the input object to the center of the coupling.
Output Offset
Distance along the shaft from the center of the coupling to the center of the output object.
Output Translation X
Distance along the X axis from the center of the coupling to the center of the output object.
Output Translation Y
Panel Properties
Width
Height
Depth
