| Author
Matrix TSL
| Version
1.2
| Category
Environmental
Temperature Infrared (Grove 101020062) component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
Please click here to download the component source project: FC_Comp_Source_GroveIRTemp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GroveIRTemp.fcfx
MeasureSurTemp
| Measures the surrounding ambient temperature,
- FLOAT
MeasureObjectTemp
| Measures the temperature of the targetted object
- FLOAT
Ambient Pin (SUR)
| Analogue input channel - which pin is the analogue input conected to?
Object Pin (OBJ)
ADC Properties
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ACD input to charge before starting the analogue sample.
Advanced Settings
Temperature Calibration
| Ambient temperature calibration value
Temperature Range
| Map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and object distance is 9CM.
Offset Voltage
| Voltage of mid level voltage after 5-10 mins to bring the sensor to ambient.
Number of Samples
| Number of samples to take to average out each reading. Default 10.
