Component: Injector (Flowcode vNet) (Test Injectors)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (Flowcode vNet) component
Comms data injector to allow components to talk to each other between instances of Flowcode. The injector allows the data to be sent and received between multiple instances of Flowcode either running on a single machine, across a network or via the internet.
Please click here to download the component source project: FC_Comp_Source_InjectorVnet.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorVnet.fcfx
Simple Single Instance
Sends out data and prints incoming data to an LCD. Uses the same port number for transmit and receive.
FC6 Icon.png SingleInstanceVnet
Simple Multi Instance
The first program sends out data.
FC6 Icon.png UartVnetDemoTx
The second program receives the data and prints to an LCD.
FC6 Icon.png UartVnetDemoRx
Remote Lock
Here is an example of using the vNet injector to simulate a multi microcontroller system.
Microcontroller 1 is connected to a keypad and has a RS232 communications connection.
Microcontroller 2 is connected to a solenoid and has a RS232 communications connection.
Any key presses detected on microcontroller 1 will be sent via RS232 to microcontroller 2. If the correct byte sequence (1234) is received by microcontroller 2 then the solenoid is fired to unlock a door for 5 seconds.
FC6 Icon.png vNet Example Node 1
FC6 Icon.png vNet Example Node 2
Communications over the vNet injector can be monitored using the console.
Modbus Master and Slave example using vNet
Example of communicating using Modbus Master and Slave using two instances of Flowcode and the vNet injector component.
FC6 Icon.png ModbusMasterDemo
FC6 Icon.png ModBusSlaveDemo
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Fc9-comp-macro.png UARTCheckRX
Fc9-comp-macro.png UARTInitialise
Fc9-comp-macro.png IOSetOutputPin
Fc9-bool-icon.png - BOOL State
Fc9-comp-macro.png UARTSend
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png vNet Injector Settings
Fc9-type-16-icon.png Network Interface
Allows different network interfaces to be selected. The current network interface can be determined by looking at the My IP properties.
Fc9-type-16-icon.png Incoming Channel
TCP Channel Instance, allows multiple servers and clients to run on the same machine or inside the same simulation.
Fc9-type-21-icon.png Incoming Port
Port used for incoming communications. 80=HTTP Ports have to match up to allow communications to be sent and received.
Fc9-type-16-icon.png Outgoing Channel
Fc9-type-21-icon.png Outgoing Port
Port used for outgoing communications. 80=HTTP Ports have to match up to allow communications to be sent and received.
Fc9-type-16-icon.png Connection Mode
Specified if this Vnet node is going to connect to another instance of Flowcode running on this PC or a networked PC.
Fc9-type-21-icon.png Circular Buffer Size
Size of the circular buffers used to temporarily store the incoming and outgoing data.
Fc9-conn-icon.png Local IP
Fc9-type-21-icon.png My IP0
Local IP address byte 0
Fc9-type-21-icon.png My IP1
Local IP address byte 1
Fc9-type-21-icon.png My IP2
Local IP address byte 2
Fc9-type-21-icon.png My IP3
Local IP address byte 3
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Show Console
