| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Alphanumeric |
LCD (Generic, Configurable) component
LCD based on the standard hitachi alphanumeric display unit.
Please click here to download the component source project: FC_Comp_Source_LCD_Generic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Generic.fcfx
|   | Clear |
| Clears the entire contents of the display. |
|  - VOID | Return |
|   | PrintString |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro |
|  - STRING | Text |
| Enter the text or variable to print to the LCD |
|  - VOID | Return |
|   | PrintAscii |
| Takes the ascii value for a character and prints the character |
|  - BYTE | character |
| Holds an ascii value. |
|  - VOID | Return |
|   | PrintNumber |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 |
|  - INT | Number |
| Enter the number or variable to print to the LCD |
|  - VOID | Return |
|   | RAMWrite |
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory |
|  - BYTE | Index |
| Values 0 to 7 |
|  - BYTE | d0 |
|  - BYTE | d1 |
|  - BYTE | d2 |
|  - BYTE | d3 |
|  - BYTE | d4 |
|  - BYTE | d5 |
|  - BYTE | d6 |
|  - BYTE | d7 |
|  - VOID | Return |
|   | ClearLine |
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data. |
|  - BYTE | Line |
| The line to clear, zero being the first (top) line of the display |
|  - VOID | Return |
|   | Cursor |
| Moves the cursor on the LCD Display |
|  - BYTE | x |
| Set the cursor position in the X plane, 0 is the left most cell |
|  - BYTE | y |
| Set the cursor position in the Y plane, 0 is the top most cell |
|  - VOID | Return |
|   | Command |
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet. |
|  - BYTE | instruction |
| Send a defined command to the LCD Screen. See datasheet for supported commands. |
|  - VOID | Return |
|   | PrintFormattedNumber |
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295 |
|  - ULONG | Number |
|  - BOOL | Format |
| 0=Signed, 1=Unsigned |
|  - VOID | Return |
|   | ScrollDisplay |
| Scrolls the display left or right by a number of given positions. |
|  - BYTE | Position |
| Holds the number of positions to shift the display |
|  - BYTE | Direction |
| 0 = left, 1 = right |
|  - VOID | Return |
|   | RawSend |
| Sends data to the LCD display |
|  - BYTE | data |
| The data byte to send to the LCD |
|  - BOOL | type |
| A boolean to indicate command type: true to write data, false to write a command |
|  - VOID | Return |
|   | PrintFloat |
| Print a Float number rounded up to a specified amount of decimal places. |
|  - FLOAT | Number |
|  - BYTE | DecimalPlaces |
| Enter how many decimal places to round up to (1 - 6) |
|  - VOID | Return |
|   | RemapCharacter |
| Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.  The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map. |
|  - BYTE | RemapIdx |
| Remap Index, Range: 0 to (Remap Characters - 1) |
|  - BYTE | SearchCharacter |
| Character to look for a replace |
|  - BYTE | ReplacementCharacter |
| New character value to use in place of the search character. |
|  - VOID | Return |
|   | Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Interface mode |
| Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency. |
|   | Data 0 (11 / 7) |
| Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode |
|   | Data 1 (12 / 8) |
| Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode |
|   | Data 2 (13 / 9) |
| Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode |
|   | Data 3 (14 / 10) |
| Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode |
|   | Register Select (4) |
| Register Select Pin - Informs the display if a command or data is about to be sent. |
|   | Enable (6) |
| Enable pin - Used to synchronise data writes to the display |
|   | Use Read/Write Pin |
| Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground. |
|   | Display Settings |
|   | Rows |
| Number of lines of characters the LCD can display. |
|   | Columns |
| Number of characters the LCD can display on a single line. |
|   | Remap Characters |
| Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings. |
|   | Delay Timings |
| Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well. |
|   | Simulation |
|   | Component Label |
|   | Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display |
|   | Text Colour |
| Colour of the font characters drawn on the display |
|   | Text Background |
| Colour surrounding the font characters drawn on the display |
|   | Display Background |
| Colour of the background of the display |
