Component: LTSR Current Transducer (Electrical)
Revision as of 16:49, 30 January 2023 by Wiki bot (talk | contribs)
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here to download the component source project: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LTSR_Current_Transducer.fcfx
Current
- FLOAT Return
Device
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
