| Author
Matrix TSL
| Version
1.0
| Category
Environmental
Pulse Oximeter (Max30100) component
Sensor designed to monitor heart rate and pulse omimetry. Connected using an I2C bus.
Please click here to download the component source project: FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
ReadRed
| Returns one of the FIFO Red readings from the last update
- UINT
ReadIR
| Returns one of the FIFO IR readings from the last update
- UINT
SetHighResModeEnabled
- BYTE
Enabled
SetLEDsPulseWidth
- BYTE
PulseWidth
SetSamplingRate
- BYTE
SampleRate
| Range: 0-7 / 0=50Hz, 1=100Hz, .., 6=800Hz, 7=1000Hz
SetLEDsCurrent
- BYTE
IR
| Range: 0-15 / 0=0mA, 1=4mA, .., 14=46mA, 15=50mA
- BYTE
Red
Update
| Reads the sensor FIFO buffer and stores the readings into local RAM. Returns the number of samples read.
- BYTE
| Sets up the I2C bus ready for communications with the sensor IC. Must be called once before calling any of the other component macros. Applies the defauilt settings from the component properties.
| Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Sensor Defaults
Sample Rate
| Sets the default sample rate
Pulse Width
| Sets the default pulse width and bit depth of the sensor measurements
High Resolution Mode
| Sets if the module defaults to high or low reolution mode
IR LED Current
| Default current to drive the IR LED
Red LED Current
| Default current to drive the Red LED
Simulate Comms
| Allows the I2C communications to be simulated and interfaced via an API component to real world hardware.
