Component: DSP Audio Output (EB086) (E-blocks 1)
Revision as of 11:48, 3 February 2023 by Wiki bot (talk | contribs)
Category E-blocks 1
DSP Audio Output (EB086) component
16-bit external DAC connected to the microcontroller using SPI.
Please click here to download the component source project: FC_Comp_Source_DAC_AD5662_EB086.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_AD5662_EB086.fcfx
OutputDAC
OutputDAC
Outputs a value to the DAC,
- UINT Output
Range: 0-65535 / 0=0V / 65535=VCC
Initialise the SPI bus ready for communications,
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
