Component: Simulated Control Load (DSP Operators)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Operators |
Simulated Control Load component
Allows a simulated load to be connected to the DSP network allowing you to model external factors such as Motor Speed, Motor Position, Temperature, Humidity, Pressure, Flow etc. Useful when used with a feedback based control system.
Please click here to download the component source project: FC_Comp_Source_DSP_SimLoad.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_SimLoad.fcfx
SimulateLoadArray
| SimulateLoadArray | |
| Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end | |
SimulateLoad
| SimulateLoad | |
| Simulates a load change with a new control value being applied and a new feedback signal gathered from the output. | |
