Component: Waveform Generator (DSP Inputs)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Waveform Generator component
A waveform generator component designed to plug into the DSP system component and allow several discreet waveforms to be generated. Functions available include: Sine, Cosine, Square, Pulse, Triangle, Sawtooth, Noise, Custom
Please click here to download the component source project: FC_Comp_Source_DSP_Wave_Gen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Wave_Gen.fcfx
Basic Sine Wave Generator
FC6 Icon.png FreqGen The frequency is controlled by adjusting the potentiometer on the panel.
The frequency generator period is controlled using the Period Offset property and/or the SetOffset component macro. The Offset value is the LUT index multiplier so a offset of 3.0 will only read every 3 values of the waveform to provide 1/3 of the period and generate 3 x the frequency. As the waveform period is being reduced there is potential for the signal to start to become less defined and more stepped.
Multi Wave Signal Generator
Switch-able mode frequency generator example file generating different waveforms depending on the value on pins RB0 and RB1.
0 = Sine, 1 = Square, 2 = Triangle, 3 = SawTooth
FC6 Icon.png FreqGenMulti
The frequency is controlled by adjusting the potentiometer on the panel, the waveform is controlled by adjusting the switches on the panel.
Generate
Fc9-comp-macro.png Generate
Assigns a single value to the specified buffer from the selected waveform data. Each call will read the next value from the waveform and will wrap correctly at the end of the data period.
ModifyPhaseOffset
Fc9-comp-macro.png ModifyPhaseOffset
Shifts the output phase by the specified absolute angle in degrees.
Fc9-f32-icon.png - FLOAT PhaseOffset
Phase offset in degrees
Fc9-bool-icon.png - BOOL Absolute
0=Relative offset to current o/p 1=Absolute offset to initial o/p
GenerateArray
Fc9-comp-macro.png GenerateArray
Fills the output buffer with the selected waveform data. If the buffer is smaller or larger then the waveform data period then the data passed will follow on correctly for subsequent cycles.
ModifyFrequency
Fc9-comp-macro.png ModifyFrequency
Sets the frequency output rate by altering the period offset to a new value.
Fc9-f32-icon.png - FLOAT OffsetRate
0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2
SetOffset
Fc9-comp-macro.png SetOffset
Fc9-u16-icon.png - UINT Offset
GetOffset
Fc9-comp-macro.png GetOffset
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-conn-icon.png Waveform
Fc9-type-16-icon.png Type
Waveform type selection
Fc9-type-14-icon.png Amplitude
Waveform amplitude or volume
Fc9-type-14-icon.png Offset
Waveform DC offset
Fc9-type-7-icon.png Calculate Data
Yes = Allows Sine, Cosine, Noise data to be generated on the fly using a calculation, provides much better resolution at the cost of processing performance. No = Allows Sine, Cosine, Noise data to be generated ahead of run time, provides fixed resolution output but is fast and efficient to generate.
Fc9-type-14-icon.png Samples
Waveform sample count, the number of data points in the stored cyclic wave look up table.
Fc9-type-16-icon.png Start Phase Angle
Waveform phase, the angle in degrees or sample in the wave to start streaming from
Fc9-type-10-icon.png Data
The raw waveform data
Fc9-type-15-icon.png Period Offset
The initial amount that the index increments through the LUT data when reading the stored waveform. 0.2 = Frequency / 5 0.5 = Frequency / 2 1.0 = Original Frequency 1.5 = Frequency * 1.5 2.0 = Frequency * 2
Fc9-type-15-icon.png Sample Period
Degrees per default sample offset period
Fc9-conn-icon.png Frequency Calculation
Fc9-type-15-icon.png Sample Rate (hz)
Allows the sample rate to be entered to allow some basic calculations
Fc9-type-15-icon.png Period (s)
The length of time in seconds that the wave period will cover at the specified sample rate
Fc9-type-15-icon.png Frequency (hz)
The repeat frequency of the wave at the specified sample rate
