Component: GLCD (EB043 v2) (E-blocks 1)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.4
Category E-blocks 1
GLCD (EB043 v2) component
Graphical display component designed to work with the legacy version 2 EB043 E-blocks.
Please click here to download the component source project: FC_Comp_Source_GLCD_EB043-00-2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB043-00-2.fcfx
EB043 v2 gLCD Example File EB043 Example Example should show the following on the display on the panel and on the hardware.
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
Plot
- UINT X1
- UINT Y1
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
SetDisplayOrientation
- BYTE Orientation
BPlot
BPlot
- UINT X1
- UINT Y1
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data
Data pin connection
Clock
Clock pin connection
Chip Select
Chip select pin connection
A0
Data / Instruction pin connection
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
User Label Text
Text to display
Component Label Scale
Physical Orientation
