Component: Injector (DS1307 RTC) ()
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Injector (DS1307 RTC) component
Comms data injector to allow simulation of a DS1307 Real Time Clock and RAM.
Please click here to download the component source project: FC_Comp_Source_InjectorDS1307.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorDS1307.fcfx
This example uses the I2C master component combined with the DS1307 injector to simulate an I2C communications bus between the target Microcontroller and the virtual DS1307 device. I2C DS1307 Example The panel displays the current time from the DS1307 RAM which is populated to match the system time.
InitialiseInjector
InitialiseInjector
- STRING InjectorName
RxByteCount
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
TxByte
- BYTE DataByte
RxByte
RxByte
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
ChangeState
ChangeState
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on.
- BYTE NewState
DS1307 Injector Settings
Circular Buffer Size
Termination Character
Device Address
Day Setting
Configures how the day of the week is calculated.
