Component: Injector (Human Interface) (Test Injectors)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (Human Interface) component
Comms data injector to allow typed data values to be inserted into a component. Allows data to be input in raw ASCII form or as numeric byte data 0-255.
Please click here to download the component source project: FC_Comp_Source_InjectorHI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorHI.fcfx
This example receives a character via the RS232 component and outputs it to the LCD, an injector has been added to allow you to type data into the console. FC6 Icon.png Human Interface Injector Example The Console window has tabs for the human interface data injector allowing you to type in data that will be received by the component.
Again the RS232 console tabs reflect the data as it is sent and received.
LCD showing received data.
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-19
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
GetConsoleHandle
UARTReceive
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-53
Fc9-bool-icon.png - BOOL State
Range: 0-1
UARTSend
Fc9-comp-macro.png UARTSend
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png HI Injector Settings
Max number of bytes that can be stored in the components circular buffer
Fc9-type-16-icon.png Data Mode
Sets the console data to interperete the data as ASCII or as Numbers 0-255
Fc9-type-10-icon.png label
Fc9-type-7-icon.png Show Console
