Component: J1939 (Misc)
| Author | |
| Version | 1.1 |
| Category | Misc |
J1939 component
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
Rx_Transfer_Data
| Rx_Transfer_Data | |
| Returns the byte count and data of the transfer message data | |
| DataBuffer | |
| Buffer to receive copied data | |
| Size | |
| Size (byte count) of buffer | |
Message_Data_Read_SPN
| Message_Data_Read_SPN | |
| Read the SPN value from the CAN data buffer | |
| SPN | |
| DataBuffer | |
Process
| Process | |
| Does the message processing. Call this often. | |
| TimeElapsed | |
| Time elapsed since last call, in mS. Can be zero for frequent calling. | |
Rx_Transfer_Check
| Rx_Transfer_Check | |
| Check for incoming multipart data transfers. If received, returns the PGN else 0 | |
Get_Address
| Get_Address | |
| Returns the device (ECU) actual address | |
Message_Data_Set
| Message_Data_Set | |
| Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF | |
| DataBuffer | |
| Value | |
Tx_Transfer_Send
Rx_Message_Check
| Rx_Message_Check | |
| If a data message has been received returns the PGN,otherwise 0 | |
Get_Status
| Get_Status | |
| Returns the system status. 0 = Ready. 1 = Waiting address claim | |
Message_Data_Write_SPN
| Message_Data_Write_SPN | |
| Write the SPN value to the CAN data buffer | |
| SPN | |
| Value | |
| DataBuffer | |
Rx_Message_Data
| Rx_Message_Data | |
| Returns the DLC and data of the last received message | |
| DataBuffer | |
Tx_Message_Send
| Tx_Message_Send | |
| Send the prepared CAN message | |
| PGN | |
| DLC | |
| DataBuffer | |
Message_Data_Clear
| Message_Data_Clear | |
| Clear the CAN Data Buffer | |
| DataBuffer | |
Rx_Message_Source
| Rx_Message_Source | |
| Returns the Source Address of the last received message | |
| Initialise the CAN network and J1939 protocol | |
| Preferred_Address | |
| Preferred Address (Requested Address) | |
