Component: LCD I2C (LCM1602) (Alphanumeric)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Category Alphanumeric
LCD I2C (LCM1602) component
Generic alphanumeric LCD display based on the standard Hitachi HD44780 controller IC. Connected using an I2C based PCF8574 IO Expander IC.
Please click here to download the component source project: FC_Comp_Source_LCD_I2C_LCM1602.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_I2C_LCM1602.fcfx
Clear
Clear
PrintString
PrintString
- STRING Text
Enter the text or variable to print to the LCD
PrintAscii
PrintAscii
- BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
RAMWrite
RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ClearLine
ClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
Cursor
Cursor
- BYTE x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Command
Command
- BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
ScrollDisplay
ScrollDisplay
- BYTE Position
Holds the number of positions to shift the display
- BYTE Direction
0 = left, 1 = right
RawSend
RawSend
Sends data to the LCD display
- BYTE data
The data byte to send to the LCD
- BOOL type
A boolean to indicate command type: true to write data, false to write a command
Backlight
Backlight
Controls the backlight on the display module
- BYTE Mode
0 = Backlight Off / 1 = Backlight On
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Channel selection
SlaveAddress
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Display Settings
Rows
Number of lines of characters the LCD can display.
Columns
Number of characters the LCD can display on a single line.
Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Delay Timings
Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well.
Background Color
Simulation only background colour, the actual hardware will have a fixed colour
Line Color
Simulation only line colour, the actual hardware will have a fixed colour
Text Color
Simulation only text colour, the actual hardware will have a fixed colour
Font
Font to use for simulation, the actual hardware will have a inbuilt fixed font.
API
