Component: SPI (CAL) (Misc)
Version | 2.1 |
Category | Misc |
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
Master_Enable_CS
Master_Enable_CS |
Outputs a low signal to the chip select pin to select the remote slave device. | |
Return |
Slave_Uninit
Slave_Uninit |
Uninitialise the Slave | |
Return |
Prv_TextConsole
Master_Transaction
GetValue
GetValue |
Reads Named property Value. | |
Name |
Return |
Slave_Init
Slave_Init |
Initialise the Slave | |
Return |
Master_Disable_CS
Master_Disable_CS |
Outputs a high signal to the chip select pin to deselect the remote slave device. | |
Return |
Master_Uninit
Master_Uninit |
Uninitialise the Master | |
Return |
Master_Byte
Master_Byte |
Sends and receives a data byte | |
DataOut |
Return |
GetConsoleHandle
GetConsoleHandle |
Returns a handle to the console used by this component | |
Return |
Slave_TxByte
Slave_TxByte |
Sets the data to be transmitted to the SPI master. | |
Data |
Return |
Slave_RxByte
Slave_RxByte |
Returns the data received from the SPI Master | |
Return |
SetValue
SetValue |
Change Named property to new Value. | |
Name |
Value |
Return |
SetPrescaler
SetPrescaler |
Sets the prescaler value for the clock divider chain | |
Prescaler |
Return |
Master_Init
Master_Init |
Initialise the Master | |
Return |
GetList
GetList |
returns Named property list | |
Name |
Return |
