Component: Hydro Encryption (Comms: Networking)
Revision as of 11:53, 3 February 2023 by Wiki bot (talk | contribs)
Author
Category Comms: Networking
Hydro Encryption component
A cipher suite to enable encryption and decryption of data messages, based on libhydrogen.
Please click here to download the component source project: FC_Comp_Source_libhydrogen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_libhydrogen.fcfx
sign_create
sign_create
Computes a signature for a message using the secret key. Returns 0 if successful.
- BYTE signature
Buffer to receive the signature. Must be 64 bytes.
- BYTE message
Buffer containing the data to sign
- UINT message_size
Byte count of the message
- BYTE secret_key
Secret/Private key to be used.Size is 64 bytes.
- INT Return
secretbox_keygen
secretbox_keygen
Creates a secret key suitable for use with the secretbox functions. You must provide a 32 byte array for the key.
- BYTE key
hash_with_key
hash_with_key
Creates a hash fingerprint of the data, using the given key. Returns 0 if successful.
- BYTE hash
Buffer for the hash. Size >=32 makes it practically impossible for two messages to produce the same fingerprint.
- BYTE data
The data buffer to be processed
- UINT size
Byte count of the data to be processed
- BYTE key
Key to be used
- INT Return
sign_verify
sign_verify
Verify the signature of a mesasge using the public key. Returns 0 if successful.
- BYTE signature
- BYTE message
- UINT message_size
- BYTE public_key
Public key to be used.Size is 32 bytes.
- INT Return
init
init
Initialisation function. To be called at the very start of your program.
- INT Return
sign_keygen
sign_keygen
Creates Private and Public key pair to sign and verify messages. Returns 0 if successful.
- BYTE Secret
Buffer to receive the Private/Secret Key. Buffer size must be 64 bytes
- BYTE Public
Buffer to receive the Public key. Buffer size must be 32 bytes
- INT Return
secretbox_encrypt
secretbox_encrypt
Encrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
- BYTE message
Buffer containing the message to be encrypted.
- UINT length
The length (byte count) of the message
- UINT ID
Message ID. Can be 0
- BYTE key
The secret key
- BYTE ciphertext
Buffer for ciphertext output. Buffer size must be at least length + 36
- INT Return
hash_keygen
hash_keygen
Creates a secret key suitable for use with the hash_hash function. You must provide a 32 byte array for the key.
- BYTE key
secretbox_decrypt
secretbox_decrypt
Decrypts a message with a secret key. A single key is used both to encrypt/sign and verify/decrypt messages. For this reason, it is critical to keep the key confidential. Returns 0 on success.
- BYTE message
Buffer for the decrypted message. Size must be at least length - 36
- UINT length
The length (byte count) of the ciphertext
- UINT ID
Message ID. Must match with the original message ID. Can be 0
- BYTE key
The secret key
- BYTE ciphertext
Buffer containing the ciphertext to be decrypted.
- INT Return
hash_without_key
hash_without_key
Creates a hash fingerprint of the data, which will always have the same fingerprint, similar to the MD5 or SHA-1 Returns 0 if successful.
- BYTE hash
- BYTE data
Data buffer to be processed
- UINT size
Byte count of data to be processed
- INT Return
