Component: Marking control (Misc)
Revision as of 11:53, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Misc
Marking control component
A control to draw markings on any component
Please click here to download the component source project: FC_Comp_Source_markings.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_markings.fcfx
DrawStripY
Fc9-comp-macro.png DrawStripY
Draw the marks on the readout Set up the position and range with SetRange() and SetSpan()
Fc9-s16-icon.png - INT OffsetX
Offset to add to X
SetTarget
Fc9-comp-macro.png SetTarget
Sets the target image to draw on
Fc9-u32-icon.png - ULONG Target
Fc9-s16-icon.png - INT AreaX
The X area to draw on
Fc9-s16-icon.png - INT AreaY
The Y area to draw on
Fc9-bool-icon.png - BOOL AutoCreate
Set true to auto-create the graphic
DrawStripX
Fc9-comp-macro.png DrawStripX
Fc9-s16-icon.png - INT OffsetY
Offset to add to Y
BoundRange
Fc9-comp-macro.png BoundRange
Bounds a range to be between RangeStart and RangeEnd
Fc9-f32-icon.png - FLOAT Range
The unbounded range
DrawArc
Fc9-comp-macro.png DrawArc
Draw the marks on the readout Set up the position and range with SetRange() and SetArc()
Fc9-f32-icon.png - FLOAT Radius
Scale of the radius to draw at
SetAngles
Fc9-comp-macro.png SetAngles
Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45
Fc9-s16-icon.png - INT Start
Fc9-s16-icon.png - INT End
SetShow
Fc9-comp-macro.png SetShow
Decides on the presentation of the dial
Fc9-bool-icon.png - BOOL ShowNumbers
True to show numbers on the dial, else false
Fc9-bool-icon.png - BOOL ShowMarks
Show marks
CalcScaleRange
Fc9-comp-macro.png CalcScaleRange
Decide the range value for a 0->1 value Returned value may be out of range
Fc9-f32-icon.png - FLOAT ScaledRange
CalcAngRange
Fc9-comp-macro.png CalcAngRange
Decide the range value for an angle Returned value may be out of range
Fc9-f32-icon.png - FLOAT AngleDegrees
CalcScale
Decide the scale (0->1) to display at given a range value
Fc9-f32-icon.png - FLOAT RangeVal
SetMarks
Fc9-comp-macro.png SetMarks
Fc9-s16-icon.png - INT Marks
Number of marks on the dial
Fc9-s16-icon.png - INT Subs
Number of marks before a 'main' mark - can be zero
ClearArea
Fc9-comp-macro.png ClearArea
Clears the draw area
SetRange
Fc9-comp-macro.png SetRange
Sets the min-max range to draw on the dial Used for setting the needle
SetGaps
Fc9-comp-macro.png SetGaps
Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1
SetJustify
Fc9-comp-macro.png SetJustify
Fc9-bool-icon.png - BOOL RAlign
True for right/top/outer alignment
CalcAngle
Fc9-comp-macro.png CalcAngle
Decide the angle to display at given a range value
