Component: Sim Switch (Push, PCB, SMT) (Misc)
Revision as of 11:53, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Misc
Sim Switch (Push, PCB, SMT) component
Surface mount sim only click switch, standard 6mm square size.
Please click here to download the component source project: FC_Comp_Source_sw_push_pcb_smd_Sim.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb_smd_Sim.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
GetState
GetState
- BOOL Return
