Component: API I2C Dummy (API Slave Devices)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API I2C Dummy component
API I2C Dummy
Please click here to download the component source project: FC_Comp_Source_temp/API_I2C_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/API_I2C_Dummy.fcfx
I2CInitialise
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
I2CReceive
- BYTE Channel
- BOOL Last
I2CRestart
I2CRestart
- BYTE Channel
I2CSend
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
I2CStart
I2CStart
- BYTE Channel
I2CStop
I2CStop
- BYTE Channel
I2CTransInit
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
I2CTransReceive
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
I2CTransSend
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
