Component: Analogue Temp Sensors (Environmental)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Author Medelec35
Category Environmental
Analogue Temp Sensors component
A range of the most popular temperature analogue sensors which are: AD22100, AD22103, LM135, LM235, LM335, LM34, LM35, LM60, MCP9700, MCP9701, TC1047, TMP35, TMP36, TMP37 & TSIC301. Uses a single ADC pin which will allow you to display the temperature in C or F. If your sensor is not listed, there is a Custom option. You will be able to enter the scale factor, offset voltage, Temperature Compensation, min and maximum temperatures If the temperature is outside the min and max values, then 999.9 will be displayed.
Please click here to download the component source project: FC_Comp_Source_temp/Analogue_Temperature_Sensors.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Analogue_Temperature_Sensors.fcfx
GetTempFloatC
GetTempFloatC
Value of the temperature in deg C 999.9 = temperature outside of sensor range
- FLOAT Return
GetTempFloatF
GetTempFloatF
Value of the temperature in deg F 999,9 = temperature outside of sensor range
- FLOAT Return
GetTempIntCX10
GetTempIntCX10
Value of integer temperature in deg C x10 E.g 22.5C will give the result of 225 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
- INT Return
GetTempIntFX10
GetTempIntFX10
Value of integer temperature in deg F x10 E.g 62.5F will give the result of 625 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
- INT Return
GetTempStringC
GetTempStringC
String value of integer temperature in deg C to one decimal place. E.g 22.5 999,9 = temperature outside of sensor range
- STRING Return
GetTempStringF
GetTempStringF
String value of integer temperature in degF to one decimal place. E.g 70.2 999,9 = temperature outside of sensor range
- STRING Return
IntValueADC
IntValueADC
The Integer ADC value of the sensor output volttage
- INT Return
VoltageADC
VoltageADC
Calculates what the approximate voltage should be based on Vref, Scale factor, Offset. For TSIC301, based on Max temp and Min temp only.
- FLOAT Return
Select Sensor
Select the required sensor. Custom allows you to enter parameters of an analogue sensor not covered.
ADC Properties
Vref (mV)
For a more accurate reading, enter the exact referance voltage.
VRef option
Conversion speed
Acquisition cycles
Total average samples
The number of ADC samples taken. The higher the number the more stable the reading.
Sensor Characteristics
Temp compensation x10
Set value to compensate for sensor and other vairations. E.g. -10 = Set the temperature 1 degrees lower 5 = Set the temperature 0.5 degrees higher
Scale factor (mV x100)
for a scale factor of 22mv/C or 22mV/F it's 2200. Scale factor is set for you automatically. It can only be adjusted when custom is selcted.
Offset (mV)
Offset is set for you automatically. It can only be adjusted when custom is selcted.
Max Temp
Max Temp the sensor can reach is set for you automatically. It can only be adjusted when custom is selcted.
Min Temp
Centigrade
0 for a fahrenheit sensor. 1 for a centigrade sensor. Can only be changed when custom is selected.
Kelvin
1 for a kelvin sensor. Can only be changed when custom is selected.
