Component: Touch Pads (EB088) (E-blocks 1)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category E-blocks 1
Touch Pads component
This board provides five touch areas for use with capacitive sensing. Hence five digital touch switches can be implemented. This component directly interfaces with the EB088 CapTouch E-block.
Please click here to download the component source project: FC_Comp_Source_temp/CapTouchEB088.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/CapTouchEB088.fcfx
GetTouchPressed
GetTouchPressed
Returns non-zero if touch detected
- BYTE Switch
0=Up, 1=Right, 2=Down, 3=Left, 4=Center
- UINT OffValue
- BYTE Threshold
Provide the threshold value for the pad to be considered touched
- BOOL Return
GetTouchValue
GetTouchValue
Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel
- BYTE Switch
Up Channel
ADC Channel number
Right Channel
Down Channel
Left Channel
Center Channel
Simulation Properties
Up Switch
On Value
Off Value
Right Switch
On Value
Off Value
Down Switch
On Value
Off Value
Left Switch
On Value
Off Value
Center Switch
On Value
Off Value
