| Author
Matrix Ltd
| Version
1.2
| Category
Sensors
Collision Detector Template component
Polls a chosen panel object to see if it has collided with another object. When collisions happen, a user notification event is generated and a pin is set or reset. Another event is sent when the two objects separate.
Please click here to download the component source project: FC_Comp_Source_temp/Collision_Detector.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Collision_Detector.fcfx
ReadState
ReadState
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
- BYTE
SetTarget
SetTarget
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
- HANDLE
Target
| The object to test for collision with.
WaitUntilHigh
WaitUntilHigh
| Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
WaitUntilLow
WaitUntilLow
| Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Pin
| The pin that should change state when objects collide or separate.
Polarity
| Active High = Pin is high when objects collide, low when they are separate. Active Low = Pin is low when objects collide, high when they are separate.
Test Object
| The object to test for collisions. A user event is sent each time this object collides with any other, or when the two object separate.
Mouse Object
| Choose an object that the user can clock on to simulate a collision when testing.
Detector Ident
| An ID value to identify this particular detector. Will be sent as the 'Ident' value for the notification events sent out so that multiple detectors can be told apart.
Timer Interval (ms)
| Time in milliseconds between collision scans. Small time = Greater CPU load Large time = More like to miss brief collisions.
